Old 02-12-2005, 10:50 PM
mb17180116 mb17180116 is offline
Exclamation 89 Cav stalls when stopped at red light
I have an 89 cavalier 2.0L 4cyl with about 120,000 miles on it. When i come to a stop light or stop sign, after about 20 seconds or so, it will start to run very rough and it will shake and stalls and nearly dies...but comes out of it every time. It only does this when stopped, and runs just fine on the highway or any other time im moving. Tried replacing the fuel filter and the mass airflow sensor...thinking maybe the o2 sensor....any other suggestions?
Old 02-13-2005, 11:55 AM
noshun's Avatar
noshun noshun is offline
Re: 89 Cav stalls when stopped at red light
More than likely the IAC valve on the TB needs cleaning out with some carb cleaner. Other than that EGR valve. But more than likely IAC as it's during idle.
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come
'Never forget Grasshopper, Not speed, smile!'
Old 02-15-2005, 01:11 AM
Re: Re: 89 Cav stalls when stopped at red light
Took out and cleaned the IAC valve with carb cleaner and a toothbrush...still had the same problem. Maybe ill try the EGR valve next...
Old 02-20-2005, 07:50 AM
public's Avatar
public public is offline
Check for a vacuum leak. This is a classic vacuum leak description.
Yes, I am retarded.
Old 02-20-2005, 09:15 PM
shottenheimer shottenheimer is offline
I had a similar-type problem with '93 Cavalier. My problem was with lock-up siliniod in the transmission. Cost about $200 to fix at a transmission shop. Dealer wanted $550. Don't know if this is true but was told this is a common problem with many GM vehicles.
Old 02-20-2005, 10:00 PM
noshun's Avatar
could have stopped the stalling for free!
Old 02-20-2005, 10:07 PM
Re: Re: Re: 89 Cav stalls when stopped at red light
Interesting. What would you have done?
Old 02-20-2005, 10:12 PM
noshun's Avatar
Re: Re: Re: Re: 89 Cav stalls when stopped at red light
Disconnected the plug for the lock-up AKA torque converter Clutch. Blue plug on the underside of the trans housing. Will stop it engaging alltogether! Lowered gas mileage on the Highway but no labout cost.
Although yours was very cheap! It's like $25 for the part and the rest is labour stripping down the trans!
