| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
ok i just rebuilt a 4G63 engine and it starts and runs... only thing is oil is leaking out of the timing cover not sure y though all the gaskets and such are on and its leaking... anyone know any Possibilities....
Re: 4G63 motor rebuild URGENT!!!!
Take the timing cover off and see where its leaking!
Possibilities of where its coming from: Crank case cover: balance shaft bolts crank seal oil pump seal loose bolts crack in the case cover Your head gasket could be cracked/torn, head might not have been torqued down right. Asking us where your oil leak is when you say its behind the timing belt cover is like me asking you what boob size the chick sleepin in my bed right now has! Its impossible for you to know~So with that said, take off the cover and observe where its leaking from. Then once you have done that, come tell us what you found, or take some pictures and post them up! |
