Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 02-12-2005, 07:25 PM
Coupejunkie Coupejunkie is offline
1994 tachometer installation trouble
Just bought and installed a cheap tach for my truck. Everything is hooked up and wired in exept for the Green signal wire.
The instructions say that it is supposed to connect to the negative side of the coil. However, when the wire is attached, the truck will not start.
I pulled the boot back and had the truck running. When I touch the signal wire to the exposed coil wire, the truck stalls. So, I guess the tach pulls too much.
Am I doing something wrong here? Is the coil weak and in need of replacement?
Anyone here ever installed one on their truck?
Thanks!
Old 02-14-2005, 10:41 PM
dstrick32 dstrick32 is offline
Re: 1994 tachometer installation trouble
If you truck is like mine it has an ignitor beside the coil. Connect green wire from tach to the solid black wire from the ignitor.
92 Chevrolet Silverado 5.7 Automatic 2X4
Old 02-15-2005, 12:45 AM
I ended up calling sunpro tech support. They said attatch the gree to the diagnostic serial port on the passenger side. I did and it works great. Pretty good looking wiring job if I do say so myself.
Old 02-15-2005, 06:34 AM
Same wire you could have just spliced into it at the ignitor and save yourself a little wiring!! But as long as your happy who else matters, except the old lady!!LOL
