Old 02-12-2005, 07:25 PM
brianeclipse98 brianeclipse98 is offline
Unhappy engine not firing...hmmmmm??
i have a slight problem, i was jumping my car today and i started to see a LITTLE smoke coming from the back of the block and i hissing..like i was burning something up. it will turn over but it wont fire the plugs? any suggestions. thanks
Old 02-13-2005, 12:29 AM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
Re: engine not firing...hmmmmm??
maybe there's a short somewhere...what kind of car do you have? make and model, also need more info. a more descriptive post would help.
Old 02-13-2005, 01:07 AM
mrrob mrrob is offline
Coil Pack Maybe Bad.
You may have a problem with the coil pack, it's located on top of the valve cover.
I have replaced many of these.
Mr.Rob
Good Luck
Old 02-13-2005, 03:06 AM
no i know its not those because i just got new ones. i also took the alternator belt off today could that have something to do with it. its like its trying to start but it just wont fire the ignition. i thought it might be the starter going out but its turning over so i dont THINK thats it. i dont think theres any power getting to the coils, just thought i would get some insite before i started replacing random things. thanks
Old 02-13-2005, 11:32 AM
btw its a 95 gsx 5sp with a 99 block in it(no idea why, thats how i bought it)
Old 02-14-2005, 10:34 PM
Is It?
Is the engine cranking, and you have pulled a few wires and the result is there is no spark present at the wire? or is the engine just not cranking?
Mr.Rob
Old 02-15-2005, 01:09 PM
the car is cranking or turning over as some would call it, i did a little more invertigating this morning and it seems theres no fuel OR spark. i pulled the ecu and checked it it LOOKS to be fine, is there a chance theres something scrwed up in the ecu that i cant see? ive been doing a lot of searching on this topic and theres been a lot of talk about the CAS going bad, is there a way to check for that? also then i tried to start it last nite(just turning over) there was a loud pop from the exhaust lke a back fire? im totaly lost
Old 02-16-2005, 11:07 PM
No Spark/No Fuel?
Your 100% of this, you checked for fuel pressure and it read 0, you pulled all the wires from the coil and check for spark? (none)?.
If so, check the basics first (Fuses!), if all are ok, you may have to find some info on the module (IGN), may be located with ign coil pack.
Keep us up-to-date.
Mr.Rob
Old 02-17-2005, 10:14 AM
checked all the fueses, there goodi did however take the intake pully off to check the cas and its busted, i dot know if it was like that before i took it off or if it did it. eiher way its being replaced and is most likely that cause of it all. now if i could only get the dam ceank pully off. ill keep you updated.thanks
Old 02-19-2005, 09:38 PM
You took the ?
I didn't follow your last message you took the cas off?
Expand please?
Mr.Rob
Did it turn out to be the timing belt?
Old 02-19-2005, 09:42 PM
mitsu_eclipse95gst's Avatar
mitsu_eclipse95gst mitsu_eclipse95gst is offline
Yea i did not get that intake pulley the intake cam gear?
1990 Mitsubishi Eclipse GSX
1995 Mitsubishi Eclipse GS-T (SOLD)
2002 VW Jetta 1.8T
Old 02-20-2005, 03:08 AM
i took the intake cam gear off and the CAS.
