Old 02-12-2005, 06:32 PM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
How to remove valve springs. Please Help.
Hey Guys
I am parting out my old engine and I have hit a problem. I have the cylinder head off, the cams, rocker arms and lash adjusters moved. Next step is the valve springs. I have a Haynes manual is it looks as though part of casting is removed but I can not get at the springs with my valve spring remover.
If you can give me any help that would be greatly appreciated.
Thanks!
Alex
"You can have everything in life you want if you will just help enough other people get what they want."
Old 02-12-2005, 08:53 PM
joemathews's Avatar
joemathews joemathews is offline
Re: How to remove valve springs. Please Help.
You need to use a socket with a hole cut out of it to make your compressor work. This way it will reach both sides of the spring and valve, and it will allow you to remove the retainer. Or you can buy a Miller's Valve Spring compressor that bolts to the head and allows you to compress the valves.
Check vfaq.com for instructions on how to compress the springs.
1996 Eagle Talon
Old 02-13-2005, 03:52 AM
kjewer1 kjewer1 is offline
AF - Advisor
My machinist will pop them all out for a 6 pack. Well worth the 10 minute drive to save the aggrevation.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 02-13-2005, 04:40 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Shit, I would do it for a case!
6 pack just doesnt do anything but make me more thirsty.
Old 02-13-2005, 12:10 PM
bighauns's Avatar
Okay I will try that out and let you know how it goes. Does anyone have any more specific information or pictures?? If not, its not a big deal. Thanks again!
Old 02-13-2005, 05:15 PM
EclipseRST's Avatar
Banned
Yea, this is me pulling out the valves on Joemathews head. You can see the valve spring compressor in the background on the other side of the head.
