Go Back   Automotive Forums Car Chat > Mazda > 626/Capella/Capella Wagon
Old 02-12-2005, 05:29 PM
lorry lorry is offline
93 626 will not start 3
Well it's not the timing belt When I had a friend turn the car over I could see the cam gear turning. throw me a bone.
Old 02-13-2005, 08:19 AM
billtsmith billtsmith is offline
Re: Car will not start 3
It's probably your immoibilizer. This has happened to me 3 times over the past 2 years. On the centre of the dash, ther is a red image of a car with a key in it,if this continues to flash after you have inserted your key - it's the ant theft device.
Old 02-13-2005, 12:07 PM
Re: Re: Car will not start 3
Thanks for the reply Bill, I looked at the display and I have no light like that on my dash. when I put my key in the ing the display lights are on both sides of the speedo? any other ideas?
Old 06-23-2005, 08:51 PM
jstone4646 jstone4646 is offline
Post Engine Wont Fire Help
Hey to all Mazda 626/ford probe/and mx-6 owners out there i had a problem with my 89 626 no turbo, 4cyl, automatic...anyways to get to the point mine wouldnt start it would roll over but wouldnt start and like many of you i checked the battery, fuel pump, coil pack, rotor button blah blah blah...well i didnt know it but there is a tiny piece called the magnetic pick-up inside the distributor housing, its pretty much just a wire or two and a small metal plate (atleast from looking at it anyways) its about 2" x 1/2" in size and costs about $75 at my local auto parts store..so if you have the symptoms i mentioned just take out the part and take it to auto zone they can test it for free...oh and dont forget to mark your distributor b4 you remove it because sorry to say i didnt and had to spend an hour re-setting the timing!! good luck
