Old 02-12-2005, 03:28 PM
GotGrip666's Avatar
GotGrip666 GotGrip666 is offline
Banned
freaking battery
damn optima battery i got it like a month ago and havnt drove my car yet this winter because of the head gasket. i start it up at least once or twice a week, but today i go outside to start my car and it turns perfectly, the i turn on my radio and five min later the car shuts off, i go to start it theres no juice. so i then jump it and it turns over, i leave it running while i go inside for five minuits then i come back and my cars off and it wont start back up again wtf , anybody got any ideas?
Old 02-12-2005, 04:04 PM
MKIII87Turbo MKIII87Turbo is offline
Re: freaking battery
Check your alternator and wiring from the alternator making sure everything is hooked up. The battery is not the problem.
Old 02-12-2005, 04:29 PM
LouieAWDTSi's Avatar
LouieAWDTSi LouieAWDTSi is offline
Def. sounds like alternator because it has the problem after the car is running. I agree with MK...check that stuff out.
--the Cruiser-->97 Spyder GST 5sp ---3 inch exhaust, boost/vac gauge, mbc, greddy turbo timer, greddy fmic, greddy type S BOV, 17in wheels
--the DD-->99 ACURA 3.2 TL
--Sold 92TSi AWD, 6-bolt, auto, evo 3 gt turbo with supporting mods
Old 02-12-2005, 05:34 PM
shadow eclipse shadow eclipse is offline
Send a message via AIM to shadow eclipse
I got an optima battery, they are well designed, very durable, and very hard to kill. Its gotta be somethin else unless you got a defective one. peace
Old 02-12-2005, 06:38 PM
GotGrip666's Avatar
Banned
well yea and it did the same thing with my last optima battery
Old 02-12-2005, 06:42 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
If your battery is going dead prematurely, it's not the batteries fault.
Old 02-12-2005, 06:48 PM
GotGrip666's Avatar
Banned
so does it have to be the alternator? because it should die when the cars running right?
Old 02-12-2005, 08:55 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
definately sounds like the alternator. around here autozone will test batteries and alternators for free on the car.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 02-13-2005, 12:34 AM
JoeWagon's Avatar
Banned
There are more things in the charging system than the alternator, but that is a good place to start. It looks like you should visit autozone for the alternator check, and hand it over to the mechanic if there is another problem.
Old 02-13-2005, 12:02 PM
correct me if im wrong but i thought that 2g's had the voltage regulator and everything inside the alternator so the only thing it could be is battery, alternator, or cables? i guess it could also be a short that only happens when the car's running but thats not very likely
-1stGenRocks-
