Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-12-2005, 02:35 PM
MKIII87Turbo MKIII87Turbo is offline
SRS Light On
95 GST. I replaced the battery last night due to it not holding a charge. Noe the SRS light is on. Any suggestions?
Old 02-13-2005, 09:36 PM
SLoe's Avatar
SLoe SLoe is offline
Is there a fuse, I haven't looked for one. I do know that the light doesn't stay on unless there is a problem with the SRS. The problem codes are stored in the diagnostic/control unit under your floor console. A dealership could read them. Hope this helps.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 02-13-2005, 11:45 PM
soyee7's Avatar
soyee7 soyee7 is offline
Banned
Re: SRS Light On
ive come across the same problem before, check the fuse for the reverse lights, for some reason there connected and if the fuse blows your srs light with come on.
Old 02-18-2005, 06:28 PM
soyee7's Avatar
Banned
Re: SRS Light On
let me know it that worked
Old 02-19-2005, 06:16 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: SRS Light On
If you take it somewhere and have the code pulled, we can tell you what is wrong. I see there is a code 16: for abnormal battery voltage. I don't know if that would do it or not. Just have the code pulled at Autozone or anther place like that.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
