Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 02-12-2005, 12:39 PM
bdq17 bdq17 is offline
1993 Rodeo oxygen sensor light
The o2 light on the indicator panel is constantly on. This is a 1993 Rodeo 3.2L. I replaced the oxygen sensor and reset the ECM but I can't get the light to go off. I've looked in both the Haynes and Chilton repair manuals but neither references the light. Any ideas? Thanks
Old 02-12-2005, 02:13 PM
Canucklehead Canucklehead is offline
Send a message via MSN to Canucklehead
I'm pretty sure that there is a screw on the back of your instrument cluster that you have to swap from one position to another to reset that light, then after 90k m. when the light comes back on you swap it back and so on and so on and so on.
2000 VW New Beetle TDI
2007 Honda CR-V
Old 02-12-2005, 03:00 PM
steveb_92rodeo steveb_92rodeo is offline
Re: 1993 Rodeo oxygen sensor light
May not be the oxygen sensor itself...the CEL barfs on a problem with the CIRCUIT in it's entirety, not neccisarily the sensor.
Check the wiring that goes to the sensor. Perhaps it was melted or damaged due to exhaust manifold heat or the like.
Not for sure, but worth a look.
O2 sensors aren't the cheapest, and I have seen melted/damaged wires before. On some of these vehicles, there are 'heated' o2 sensors, which the power sometimes feeds off the fuel pump circuit.
Wiring is worth a look before going any further.
Steve
Old 02-12-2005, 03:28 PM
Thanks, you were right, it is a reminder light that comes on every 90K. Quite the project to reset the light.
