Go Back   Automotive Forums Car Chat > Toyota > Supra > Maintenance
Maintenance Have questions? Find answers. Help out fellow Supra owners.
Old 02-12-2005, 12:06 PM
StoryOfTheUsed StoryOfTheUsed is offline
boost leak?
whats a boost leak? and if you have one how would you fix it?
Old 02-12-2005, 01:33 PM
flyinMKIV's Avatar
flyinMKIV flyinMKIV is offline
AF - Advisor
Send a message via AIM to flyinMKIV
Re: boost leak?
a boost leak is where the turbo is losing boost because there is a leak somewhere. They can be caused by several things. The most common that happen are when there is a vacum line not hooked up somewhere. The best way if you have that problem is to check and make sure your hoses are tight and check the gauge.
02 Honda Accord (Sold)
93.5 Supra non-turbo (Sold)
94 Lexus GS300: 2jzgte swapped (sold)
08 Scion TC (daily driver)
94 Supra Single Turbo (Sold)
97 Top Secret Widebody Supra Turbo (Work in progress)
If your talking trash, I'll be showing my ass
http://www.automotiveforums.com/vbul...d.php?t=535850
http://www.automotiveforums.com/vbul...d.php?t=212356
Old 02-12-2005, 02:04 PM
projectsupramk3's Avatar
projectsupramk3 projectsupramk3 is offline
Send a message via AIM to projectsupramk3
Re: boost leak?
Exactly, you will have unusually low vaccume on a good boost gauge. Also don't forget your plastic IC pipes and rubber connectors that can easily split and leak are getting very old now. It's pretty much basic maintanence to replace them, might as well upgrade at the same time. Finding boost leaks can be tricky sometimes depending on where the leak is of coarse. A can of starting fluid sprayed around where you think it's leaking will tell you when the engine changes (at idle) from sucking in the spray.
