Old 02-12-2005, 09:24 AM
Mainaer64 Mainaer64 is offline
Send a message via AIM to Mainaer64 Send a message via Yahoo to Mainaer64
94 caravan(non turbo) fault code 54
Engine running rough, but does start. Code flashes 54. Need help to determine what this could be.
Old 02-12-2005, 12:24 PM
A. Souphound A. Souphound is offline
Re: 94 caravan(non turbo) fault code 54
No cam signal at PCM.
Since the engine will start, Check the Camshaft position sensor wiring up to the PCM. I would clear the codes (remove the (-) battery cable for a few minutes and try it again to see if MIL light comes on.
Alvin
Old 02-12-2005, 02:45 PM
It is a 3.0 l engine
Old 02-13-2005, 09:09 AM
I see in your new 'thread' you have determined the cam sensor is not faulty, so I take it signal voltages and reference voltage are correct? If any of these are not correct, the engine will run, but it will be out of time.....and run rough.
Alvin
