Old 02-11-2005, 11:03 PM
stealth*mode stealth*mode is offline
Angry No reverse on manual transmission
I have a 1989 f150 with a 4 speed manual tranny.The problem is that when I try to put it in reverse it will not stay there.I have to hold the gear shift back for me to have reverse.please help ....the gear shift is in the floor.
Old 02-14-2005, 03:48 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: No reverse on manual transmission
Sounds like a detent ball has come loose.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 02-14-2005, 06:58 PM
Re: Re: No reverse on manual transmission
Sorry Im a novice.What is a detent ball and where is it located?
Old 02-14-2005, 07:34 PM
mustangmike351c mustangmike351c is offline
Re: Re: Re: No reverse on manual transmission
its a ball that has a spring under it and when you shift into gear the ball is pushed into a detent to help hold the shift fork
Old 02-14-2005, 07:49 PM
Re: Re: Re: Re: No reverse on manual transmission
Thanks for the info
