Interval for changing manual trans fluid?
I have a 2001 Accord, 4 cyl, manual trans, almost 90K miles on it. How often does everyone change their manual trans fluid? The Service Manual for my year says to do it every 120K miles or 6 years (whichever comes first). Should I wait that long?
Re: Interval for changing manual trans fluid?
What does it specify for lube? If gear oil, 80W90 or whatever, that's fine. Most cars go to the junkyard with the same gear oil they left the factory with. It's not something most people change, but can't hurt. It doesn't break down very easily, and isn't subjected to much abuse or temperature. It can become moisture contaminated, if the vent is not working right. Some cars used ATF for gear oil, it should be changed a little more often. When I change it, I go to synthetic. It seems to improve shifting ease, and will "climb" the gears and lubricate quicker in cold temps.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made... ...empty gun rack. |
I change mine every 30-40k or so...yes many cars have the same gear oil in the junkyard as they had in the factory...but that doesn't mean it is the best idea to let it go that long. 30k is a bit often, but it only takes an hour tops to jack the car up, drain it all and refill it, so why not do it at least every 45-60k. Your tranny will shift more smoothly and will last longer. It's just a good idea if you are one for preventative maintainence.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
Re: Re: Interval for changing manual trans fluid?
Manual transmissions on Hondas take 10W-30 or 10W-40. Honda recommends their "Honda Manual Trans Fluid", which is probably just 10W-30 with some extra stuff in it. I had a friend that had a 89 Accord Lxi with a manual trans. He took it to a Jiffy Lube type establishment to have his trans fluid changed and they put in regular gear oil (85W). He could never keep it in 5th gear, it kept popping out. It turned the 5th gear blue. |
I have a similar question, I'm not sure if it's been changed though. Is it part of regularly scheduled maintenance? If not, could this explain why I have to really push it into reverse or first gear sometimes? And lastly, should I have it flushed and then refilled or just drained and refilled?
I WANTED TO DO THIS BUUT WASNT SURE about the process. DOnt you need like a funnel with a long hose on it that fits that plug???
1995 Honda Accord Ex 5spd Sedan AEM CAI Accel 8.8mm wires ![]() Flowmaster Catback Prelude directional wheels Megan Racing: -Front and Rear Upper Strut Bars -Rear Lower Tie Bar "To be fast and sound slow, or be slow and sound fast? Dont really know which is better, but i definitly know what i am and thats safer "Check out: www.EastCoastHonda.Org
Yup a funnel and a couple feet of hose will do the trick. |
