Old 02-11-2005, 10:01 PM
Powerefx Powerefx is offline
Dual SE 15 ported box question
Hey guys
Do yall think 5.8 Cuft^2 is enough for two se 15s at 32hz tuniing? SHould i devide the box throught the middle with another mdfboard for seperate cabins? Should i just construct a single large prot, or two ports for each? What sqin area should i use for the ports?
Old 02-11-2005, 10:59 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Dual SE 15 ported box question
no, each one needs closer to 4cf, which means the total box will need to be around 8cf. After you add in port and sub displacement it will easily be over 10cf, probably closer to 12cf.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 02-12-2005, 03:40 AM
ngsm13's Avatar
ngsm13 ngsm13 is offline
Send a message via AIM to ngsm13
Re: Re: Dual SE 15 ported box question
Yup, as stated above...optimal would be 8 cubes NET. The absolute minimum i'd shoot for would be 7 cubes NET. As far as tuning and port area, I'd go with 32hz and at least 70-80 sq. in. of port! Hit me up if you need a precise custom enclosure design. Can design and lay-out all specs for you, and include an exact cut-sheet listing exact size of every piece needed to be cut for $10. peace
NG
I design custom enclosures!
And...my sig is short!
Oh and.. YOU suck balls...
