Old 02-11-2005, 08:40 PM
cavf150 cavf150 is offline
Question 4.9 inline six temp gauge fluctuation
Hey,
Can anyone give me advice on why my temp gauge has gone on the fritz? At start up all is fine , 5 miles down the road the gauge rises to the O in the gauge then suddenly goes back to normal. Then it climbs slowly again then back to normal. Fluid level is at the top and shows no leaks. The oil is w/o freeze in it and is at full. Can a bad cap cause this, or a sender unit? Where is the sender unit located on the engine? Engine has a/c. Too cold here to turn it on. Heater throws hot air and the top rad hose is hot. Could a air lock have developed somehow? Engine is not overheating!
Thanks,
Old 02-12-2005, 06:23 PM
andy2005 andy2005 is offline
Re: 4.9 inline six temp gauge fluctuation
I have heard that after 1988 Ford gauges are basically a light with a needle hooked to it. My guess would be that it everything elese seems fine, its probably a sending unit.
Old 02-12-2005, 08:09 PM
mustangmike351c mustangmike351c is offline
check your thermostat it may be sticking
Old 02-12-2005, 08:10 PM
ModMech's Avatar
ModMech ModMech is offline
The temp gauge is a real gauge, I suspect either the thermostat is sticking, or the sender is bad. Since you need to drain the coolant some anyway, I would replace both with FACTORY replacement (Motorcraft) parts.
Old 02-13-2005, 08:48 AM
Re: Re: 4.9 inline six temp gauge fluctuation
ANDY,
Thanks for the input, I am starting with the sender
cavf150
Old 02-13-2005, 08:50 AM
Mike,
Sounds like it. does a thermostat constantly open and close?
cavf150
Old 02-13-2005, 08:54 AM
ModMech,
Seems to be the consensus of all replies, I am changing the sender 1st
The thermostat change is pretty straight forward and I'll do it next.
cavf150
Old 02-14-2005, 03:33 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Not unless it gets cold coolant flowing by it. It will fluctuate a bit until the engine's been running for awhile.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 02-14-2005, 07:26 PM
Mike,
cavf150
its should only open at the temp it is made for but if its sticking it will not open until it gets hot and then open util it cools back down and it may stick open and over cool making the temp go all the way up and back down many times
