Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 03-18-2002, 02:11 AM
gthang gthang is offline
Send a message via ICQ to gthang
How do you lower the clutch pedal?
I was wondering if anybody can provide details on how to lower the clutch pedal so that it's closer to the floor. My clutch engages high anyway (yeah, clutch is going) so I don't really need to depress it very far.
I've seen it done before on some cars and was wondering if it's possible on the G20. I'm not attempting to change the engage point here, just trying to lower the pedal.
Old 03-18-2002, 09:21 AM
NismoPC's Avatar
NismoPC NismoPC is offline
Look under the dash. Right above the pedal is a neutral/starter switch. It has a 12MM nut on it. (This is from memory. I'm at work right now)
1. Remove the power connector from the switch
2. Loosen the 12MM nut
3. Twist the switch clock-wise
4. Test pedal height to your likeness and re-adjust switch
5. Tighten 12MM nut down
6. Reconnect power connector
This will shorten the adjustment of the clutch pedal to floor distance.
Anyone else have another solution?
Brandon
'96 G20 - modified
