Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 02-11-2005, 07:23 PM
authenticy authenticy is offline
Question PK3 Problem
I have a 2000 chevy venture with delayed starting problems. We have decided that nobody really has a clue on the pk3 system at all, (not even the dealer) and so I am trying to understand the book I have from AC Delco on the passkey system. When I read through the book it reads like there is a coil around the key lock cylinder that works as the exciter for the transponder in the key so that it will communicate with the pk3 module. I am just wondering if anyone knows if the exciter for the key transponder is in the lock cylinder or if it is in the pk3 module that goes around the lock cylinder. Everyone I talk to says its in the module but the book actually makes it sound like it isn't. We have replaced the pk3 module and that didn't fix the problem so I'm thinking that maybe it is in the cylinder and wondering if I shouldn't replace that. I am just wondering if the resistors or coils could be worn which would cause the delay in starting. Sometimes it starts right up and other times I have to hold the key in the start position for 3-10 seconds before it will fire. Any help is appreciated.
Old 02-13-2005, 10:56 PM
hugaminivan hugaminivan is offline
Re: PK3 Problem
Try this link and see if this helps. I browsed it for a little bit, and I think I kinda understand what it is talking about, so it might help you even more.
http://www.locksmithcharley.com/transponder.html
If it helps, let me know.
