Old 02-11-2005, 06:58 PM
ral3ph ral3ph is offline
Angry 99 blazer won't start
hi we are having problem with our blazer not starting i put a new plug on a wire to see if there was a spark could not see one,first can you still do this to engine using an extra plug to see if any spark and second does anyone have any ideas.
thx for your help
Old 02-11-2005, 09:27 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 99 blazer won't start
check all plugs and see if there is spark in any of them.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-12-2005, 04:05 AM
Re: Re: 99 blazer won't start
if no spark in any what do u suggest
Old 02-12-2005, 08:35 AM
blazee's Avatar
blazee blazee is offline
Problem?
First you should check your fuses.
If the fuses are good. Test at least two plugs for spark. If no spark. Test for voltage at the coil, if there is no voltage at the coil,
let us know and we will assist you in testing the ignition circuit.
If there is voltage follow the procedure in this image:
The Specifications it refers to at the begining of the chapter are:
Primary resistance..........0.2 to 0.5 ohms
Secondary resistance......5,000 to 25,000 ohms
Old 02-12-2005, 12:29 PM
BlazerLT's Avatar
AF -Advisor
Also check the main coil wire going to the distributor cap.
Old 02-12-2005, 08:55 PM
hi thx for the info found the problem the rotor fell apart in the distrubutor cap.heres another question for u when its engine is cold we have to turn over for few seconds before it starts any ideas on this problem.
thx for your help
Old 02-12-2005, 09:48 PM
BlazerLT's Avatar
AF -Advisor
Check you battery voltage when engine is off and when running. Use a voltmeter.
Also, have you ever done a tunup? Did you replace the cap and rotor?
Ever changed the fuel filter?
Old 02-12-2005, 10:25 PM
did the tune up but didn't change fuel filter,where do they hide it
thx
Old 02-12-2005, 10:41 PM
BlazerLT's Avatar
AF -Advisor
What did this tuneup contain?
Old 02-13-2005, 01:00 AM
i put new plugs new rotor and cap
Old 02-13-2005, 01:08 AM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: 99 blazer won't start
Lot more to a tuneup than that.
Old 02-13-2005, 01:54 AM
slreno1217 slreno1217 is offline
Re: Re: Re: Re: 99 blazer won't start
ok then what else is there? gees .. hate people that just part answer a question!
what more is there.
Old 02-13-2005, 02:12 AM
BlazerLT's Avatar
AF -Advisor
I am trying to get you to use the search feature and find out for yourself.
Old 02-13-2005, 05:51 PM
hi can u help on how we search and where it is.
thx for your help
Old 02-13-2005, 05:55 PM
blazee's Avatar
Problem?
The fuel filter is inside the the frame rail on the driver side just in front of the tank.
