Old 02-11-2005, 06:12 PM
milton666's Avatar
milton666 milton666 is offline
Send a message via MSN to milton666
Exclamation huge oil level problem need help now
k, ive got a huge problem right now i got my car back from my mechanic and he told me when he changed the oil he put 5 quarts in it, last time i changed my oil i only put like 3 in it. now im about 20 miles away from my house, checked my oil and it's about an inch higher than the top mark on my dipstick, so i was just needing to know wtf am i supposed to do? i dont wanna risk driving it without knowing for sure. it's a 95' gst, does anyone have any clue what i can do, im kinda in a jam so would it be ok to drive it, or is there any way i can get sme oil out of it since i cant really get under it right now? thanks
95' Gs-t (broke the fuck down...)
68' Mustang getting reassembled right now, 82.763% done
http://www.tagworld.com/milton666
Old 02-11-2005, 07:48 PM
GotGrip666's Avatar
GotGrip666 GotGrip666 is offline
Banned
Re: huge oil level problem need help now
you can drain the oil a little bit,bUT it will be very messy seeing as your not draining all og it. justtake out the oil plug and let it drain for like 30 seconds then put it back in
Old 02-11-2005, 07:54 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
You can drive it BUT be real easy on it....
You MUST have a word with your mechanic this is something he should have checked before you even got your keys back!!!!! How qualified is he if he can't even fill oil to it's proper level?
Easiest thing would be to open the drain plug and let enough seep out until proper level is acquired.
Last thing is find a new mechanic.....
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 02-11-2005, 07:57 PM
GotGrip666's Avatar
Banned
yea deff, was he smoking somthing ? its not like you have a 5.0 and even then i dont think your would need 5 quarts
Old 02-12-2005, 12:51 AM
kjewer1 kjewer1 is offline
AF - Advisor
Our motors take over 4 quarts. Damn near 5 with a new motor and filter. A common mistake is filling the oil up to the mark with the front end jacked up. The dipstick is at the front of the motor on our cars, so you should be able to figure out why. I always leave it half a quart low, lower the car, then top it off. Run it, and check it again. Odds are he did this on a lift though, so I dont know how it happened. How much is an inch on the dipstick? I avent looked at one in a while. By looking at the distance between the marks you can estimate. FOr example, if the marks are 2 inches apart, one inch over is an extra half quart.
Either waym why even both posting about it. In the same amount of time you could bring it back and show him the dipstick. If he doesnt drain it and refill correctly, call him an asshole, and go home and do exactly that yourself. It'll cost you 5 bucks.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 02-12-2005, 03:34 PM
milton666's Avatar
yea i was only posting this last night cuz i was at my girlfriends house and wanted to get something done about it fast but its kinda hard getting under our cars without a jack or a lift, but i found a dsm chat room and someone suggested driving up on a curb and letting some oil out which is just what i did. it worked except after that i was covered in oil, it worked out though cuz my girlfrined thought it was hot oh well works for me i guess...
