Old 02-11-2005, 05:01 PM
sykopenguin sykopenguin is offline
Send a message via AIM to sykopenguin
Gas leaking out!!!
Ok so I'm at the gas station today filling my tank up with gas and BAM!! all the gas comes pouring outta the tank ... I'm like totally freaking out!!!
WHAT WENT WRONG!!!
AHHH
Serioulsy need help quick!!! :-p
So yeah any ideas???
Old 02-11-2005, 05:51 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Gas leaking out!!!
The whole thing emptied?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-11-2005, 11:42 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
WHAT WENT WRONG!!!
AHHH
Yea man, You gotta give us more info, How much gas? Where was it coming from, the filler neck, the bottom of the truck?
The same thing happened to me this morning and it was the frigging gas pump nozzle not shutting off. Have you had any work done to the tank recently?
Old 02-12-2005, 12:52 PM
The gas leaked out from the tank under the truck on top of the tank where theres a circular opening. It leaked all the gas out except about 2 gallons...enough to get me home.
Old 02-12-2005, 12:54 PM
BlazerLT's Avatar
AF -Advisor
How can the whole tank leak out from the top?
Old 02-12-2005, 01:05 PM
Ok here's what I saw and I'm totally stumped....put about $30 worth of gas in the tank...the gas pump stops and I start hearing this sounding the fluid was hit the ground.... it was my gas... seriously it all just starting pouring out of the top of the tank....when it was done doing this...i look under the car and on top of the tank...there's this circular opening with wires and fuel lines i guess coming out of it...thats where all the gas came out of...
Old 02-12-2005, 01:29 PM
Big Tall Dumb Ass
Gas tanks just don't moramlly bust open. Was everything o.k. prior to filling the tank? Were you 4 wheeling or have any repairs done to this area? It doesn't seem phsically possible to drain the entire tank from the top. I'd check the filler neck and look at the top of tank and also check for broken fuel lines etc.
Old 02-12-2005, 01:31 PM
No wasn't 4 wheeling....no never had work in this area... was just filling up my gas tank... it never did this before.... if the filler was broken how come all the gas didn't drain out until i was done pumping??
Old 02-12-2005, 04:04 PM
Fractured1 Fractured1 is offline
a simple question, was the truck running at the time you were filling it.
Old 02-12-2005, 04:25 PM
BlazerLT's Avatar
AF -Advisor
The whole tank cannot drain out through the top.
Old 02-12-2005, 04:36 PM
no the car wasn't running.....then do you guys have any ideas where all the gas drained out from....it was definitely something above the tank...cause the underside of it was dry
Old 02-12-2005, 04:50 PM
Big Tall Dumb Ass
I am sure you saw what appeared to be a lot of gas, but if you had really drained 15+ gallons, you'd have been literly in a lake of gasoline. Does the truck still run? Did you check to see if there was any broken lines or see any openings in the tank. Have you dropped the tank to inspect it?
Old 02-12-2005, 05:07 PM
BlazerLT's Avatar
AF -Advisor
WOULD YOU STOP OVER EXAGGERATING THINGS!
First the whole tank emptied out, then now only out the top?
how much really came out? Did you over fill it?
Old 02-13-2005, 11:58 AM
Found the prob....there were 2 bolts missing outta my gas tank.... -_-....i wonder how that happened...
Old 02-13-2005, 02:52 PM
BlazerLT's Avatar
AF -Advisor
Two bolts missing, where?
Stop being so general. It is getting really annoying.
