Go Back   Automotive Forums Car Chat > Honda > How-To's and Walk-Through's
How-To's and Walk-Through's Here's where we show you how it's done!
Old 02-11-2005, 04:39 PM
jerryb18 jerryb18 is offline
hlp wit cylinder head cleaning
i was just wondering if anyone knows how to clean up the exhaust manifold side of my cylinder head, that whole side likes to be scortched and i just want to brg back as much shine as possible
any hlp greatly appreciated thanks
Old 02-11-2005, 07:28 PM
lkailburn's Avatar
lkailburn lkailburn is offline
Send a message via AIM to lkailburn
Re: hlp wit cylinder head cleaning
easiest way is to take it to a shop and have them wash it/acid dip. its not easy to remove built up carbon deposits but its usually onle like 20 bucks to have them do that.
just make sure you have new valve seals and cam seal. i personally would strip it all down first then take it to them but i suppose you could just hand them the complete head
i've got a y8 head that i've taken apart, cleaned, lapped the valves etc etc. and engine degreaser works well with just simple cleaning but doesn't remove any carbon build up. plus i found that if i did not put a little oil in the valve guides they began to show signs of rust.. from the harsh chemicals in the degreaser.
so there again i would recommend the shop because they will use safe chemicals(or so ive been told)
mine:
Old 02-12-2005, 04:19 PM
cool thanks for the advice i think i will just strip it down and bring to shop, thanks again man
Old 02-15-2005, 11:37 AM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
also to help a bit with the removal of that carbon buildup you can use the typical shop method of kerosene, and oil mix, and a scotchpad or fine grit wet sandpaper... NO POWER TOOLS!! unless you truely know what you are doing (port matching, and port flow only for power grinders/die grinders).
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
Old 02-15-2005, 08:08 PM
lkailburn's Avatar
np man glad i could be of help
