i knoe everyone is goin to tell me to look on google and stuff but i looked for quite a while and i cant find a guide to remove the stock stereo from my car. could someone pleae either give me a site or some advice on how to remove it so i can put my new one in...
thanks
![]() RB20DET, 260whp, Drive to Destroy. |
Re: Stereo installation...
If it's anything like a 94 Altima, just take the console out (first it's the shifter trim, then this piece under the steering wheel then the console trim) then you take this big bracket that's attached the the cup holders, stock head unit and the storage thing under the radio, then you take the stereo out of the bracket aqnd reverse for install.
its nothing like the altima.. and i see you've been experiementing logik!!
i'm assuming its from an s13 take the whole center console off which goes from around the shifter to around the climate controls.. then on either side of the unit will be two screws.. take 'em out and your unit should be loose.. so should the radio.. HEYOOOO.. sorry bout that.. anyways, once you do that, lift it out carefully, unplug the harnesses and antenna cable.. there you go.. if its for an s14 then i have no clue.. haven't looked at one closely enough
http://www.cardomain.com/id/dbo240 ![]() ***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE*** |
He has a 1996 S14....check the sig, and the S14 is very similar to the Altima (same Haynes manual).
its an s14, but logiks cant be right, no offense, but i dont have cupholders...
I just looked, it's Chilton's not Hayne's, but anyways, you take off the shifter trim, then you take out the center console part that has the radio in it, there 4-6 screws in total, wow, will you look at that, it's basically what I said for in my first post!
This link used to have pictures, but they are broken now. Maybe you can follow with the descriptions on the side....http://www.carstereohelp.com/stereoremovalNis240sx.htm
sorry logik i wasnt tryin to be a dick... thanks for the info ill have to do it tomo... goin to improve my car a lot (the stock is shit)
thanks carfreak... the pictures even work for me
man i've been having brain diarreah the last few weeks
Re: Re: Stereo installation...
LMAO!!!!!! hahahahahah
![]() "I got that hustle in my genes like high blood pressure" -E-40 |
