Old 02-11-2005, 01:43 PM
TurboLS1 TurboLS1 is offline
DIY Turbo System
I've been scrounging for parts for a few months and I'm finally going to get it running this weekend. I've kept it under $1000. I'm keeping my fingers crossed that all goes well.
More details here.
02 Z28
DIY Rear Mount Turbo
Old 02-11-2005, 03:36 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
Re: DIY Turbo System
hmm.. interesting
btw, where are you mounting your turbo? If your going to mount it by the back axle like the remote mount kits you can buy, I predict you'll get very little, if any performance gain with that holset unit..
The turbos used in remote mount systems have a totally different turbine wheel than a conventional turbo, A conventional turbo wont work in place of a remote mount, and vise-versa
either way, curious to see the results and where you take it from there, keep us posted
1991 Camaro Z28
Old 02-11-2005, 06:33 PM
Agreed, the STS rear mounts use a 60-1 with a .82 A/R. The Holset I am using spooled around 3K and gave me 5psi by 5500 RPM.
Not ideal, but it's a good placeholder until I get a 60-1. I will post my final results soon.
I know of one guy who used an off the shelf T70 on his DIY rear mount. He had very good results.
02 Z28
Old 02-11-2005, 07:24 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Are you planning on getting this car dynoed to see how much of a gain your going to be getting?.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 02-11-2005, 08:31 PM
Re: Re: DIY Turbo System
Yes, I'm going to get a dyno tune. I'll do it for the Holset and the new turbo.
02 Z28
Old 02-12-2005, 04:54 AM
DaMoNe6969's Avatar
the difference isnt just in the trim and a/r.. the wheels are a completly different design the turbine wheel in the RMT is meant to catch ALL the air that comes in.. nnot a very ifficient design IMO..
but ide really like to see how you make out with it! maybe im wrong! Ive jsut never had faith in the remote mount systems.. they will never compare with a conventional turbo set up
1991 Camaro Z28
Old 02-12-2005, 10:42 AM
I took it for a few spins last night. It put me back in the seat and kicked the tail out sideways! There is a very small lag, then the boost comes on like a frieght train. I need to put a wastegate on because I saw 5 or 6psi by 5K RPM. I have not gotten into full throttle yet.
So far, I am very pleased with the results.
02 Z28
Old 02-12-2005, 11:38 AM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
One thing I would suggest is to maybe relocate your MAF before the turbo. A turbo is not 100% sealed, every spring they reccomend to clean your pipes and intercooler because a thin film of oily sludge will form over everthing. Well the wires in the MAF are extremely sensitive. getting this sludge on them will just kill the sensor.
Air flow before the turbocharger is the same as airflow after the turbocharger. The only thing that is affected is air density, which the MAF does not measure anyway. The turbo buicks have the MAF before the turbo and they work fine so you should be able to.
Also, are you intercooled?? if not I would suggest it. If you have not room, the perfect solution is Alcohol injection. If you are interested let me know and I will explain it.
Hypsi87
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 02-12-2005, 11:05 PM
I'm keeping the blow through setup. No need to change to a draw through.
I'm familiar with the Alky injection. I may set one up on a hobbs to activate over 5psi.
Thank you for the advice!
02 Z28
Old 02-13-2005, 04:48 PM
Hypsi87's Avatar
Thats cool, It's strange to find someone that is familiar with the alky injection stuff.
Also I have a TE-63 that would be very nice on that setup You would need to get like a .95 AR 4 bolt housing for it but, all it has is about 4k and 20some 1/4 mile passes on it. If you are interested give me a PM.
I have to say I am not a big fan of the remote mount stuff but, your kit is impressive, I like it
Back in action!!!!
1999 Ford F-250
ASE Certified in...
Mobile AC
On highway trucks.
Member of
Old 02-13-2005, 07:31 PM
I may be interested in that turbo.
I was skeptical on the rear mount also. It is not ideal, but it is fun to drive. I figured that I would give it a try to find out for myself. I may do a conventional setup on it next year, but so far I like this kit.
02 Z28
Old 02-13-2005, 08:48 PM
LT1MAN LT1MAN is offline
Banned
did you install that yourself? if so how much of a pain in the a$$ was it, how long did it take, how much $$$, etc? i need a turbo set up for cheap.
Old 02-14-2005, 12:39 AM
I fabbed up my kit. It only takes 1/2 day to install once all the parts are made/bought and all of the systems are figured out.
The STS kit comes complete and is less than $4,000 for your car (STS Turbo). With normal hand tools, it can be done in a weekend or less.
02 Z28
Old 02-14-2005, 12:50 AM
FireFox05's Avatar
FireFox05 FireFox05 is offline
Send a message via MSN to FireFox05
They claim 6 hours on their site for someone who can read and knows how to use a wrench.
