Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 06-28-2001, 04:47 AM
maxima_smx_gtr maxima_smx_gtr is offline
Send a message via AIM to maxima_smx_gtr
Unhappy Help ASAP!!!!!!!!!
My 95 GLE just have a Check Brake ligh and Check Battery Light came on at the same time last nite. Dont know where to check first...
and the engine sound like its running really hard even at idle.
b4 this happen i just mod some lightning stuff...
Rewire BLinkers to stay on all the time, Make Corner Light at as blinkers...swap the tailight Fuse from 7.5 to 15 cuz 7.5 blew cuz cant handle the extra power needed for blinkers to stay on
Please help with suggestions, really worry cuz i'm in a bugeted situation...
Old 06-28-2001, 04:50 AM
oh yea i forgot to say is my Antifreeze fluid is close to Min.
Old 06-28-2001, 12:36 PM
Nizmolee Nizmolee is offline
Send a message via AIM to Nizmolee
refill your antifreeze. See if theres any problem with your car if its running. you can read the code and taking apart the two screws located on the driver side kick panel to the right where the gas pedal is.. when you take this out you will see the ECU with a screw and see a clear tape that says do not tamper. get a flat move it clockwise ( not to hard) until it stops for two sec. and then do it reverse for 2 second and repeat this step again and this should reset the check engine light. good luck!
98 Auto NOS Maxima.
Old 06-28-2001, 10:48 PM
KAM KAM is offline
Sounds not too bad
Usually when the idiot lights come on, there is a problem with the charging system. Make sure your belt is tight, alternator connectors on. If still on, get a shop to do a load test on your charging system, and pony up some hard earned dough for an OEM alternator. Cheap ones will crap out very quickly!
Old 06-28-2001, 10:59 PM
KAM you're rite
YOu're rite the Alternator went bad, i ask 2 shops and they checked it for me, no charge at all. they replaced it for or 180, is that a average price or they overcharged me?
Help Asap Help Won't Start 95 Blazer rental blazer Blazer 4 12-25-2005 06:44 AM
need help asap please help atv087 Eighty Eight 2 08-31-2005 04:17 PM
HELP, does anyone know how to connect the heat in a ford escort '88? HELP ASAP Lotus War Escort 1 06-06-2005 12:22 PM
Need Help Asap Asap Asap G35turbo 3000GT/Stealth 4 02-02-2005 11:41 AM
HELP! tail lights out need help ASAP SKiTTeR KRiTTeR Integra 2 12-14-2002 11:53 PM
