Old 02-11-2005, 01:35 PM
Dadio406 Dadio406 is offline
Unhinged Lancia Rallye 037
Hi All
My current project is the Revelegawa Lancia O37 and in a fit of enthusiasm just after Christmas I decided I would add a lot of extra detail, coolant header tanks, fuel tanks, front space frame, wiring and plumbing etc. I used my trusty razor saw to remove the rear deck and the small opening on the 'bonnet' I decided to leave the doors in place.
Problem is when I made up the hinges to re attach the rear deck they need so much offset (to allow the deck to swing up) that they cut into the rear bulkhead window ( and look a bit agricultural).
The original car had plain hinges surface mounted on the roof but recreating these in 1/24?????? well you know what I mean. Any body out there solved this problem in past life?
Oh and by the way, I already know I shouldn't have removed the deck in the first place?
Old 02-11-2005, 02:11 PM
SteveK2003 SteveK2003 is offline
Send a message via AIM to SteveK2003 Send a message via Yahoo to SteveK2003
Re: Unhinged Lancia Rallye 037
Lemme look at my kit when I get home and I'll see if I have any ideas for you.
Old 02-11-2005, 02:39 PM
freakray freakray is offline
AF Modelrater
Sakatsu make a set of white metal hinges which are functional and look like the real thing in scale.
I suggest getting some if you can.
AF User Guidelines
Old 02-12-2005, 08:41 PM
p9o1r1sche's Avatar
p9o1r1sche p9o1r1sche is offline
Registered User
I believe the Studio 27 photoetch plate has functioning hinges also.
