Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 02-11-2005, 12:28 PM
NJH_Habitatpro NJH_Habitatpro is offline
Send a message via AIM to NJH_Habitatpro Send a message via Yahoo to NJH_Habitatpro
Idle Control and PCV Hoses/Valve fixed here is how to do it. Got Spudder and jerking?
Check all the vaccum hose's. Deffently the ones on the evaperation canister. That is were mine was split. But check the hose's all mine are hard plastic. But the rubber things that connect the hoses everywere check those for cracks. If they do eitehr replace them or put clams on them. I did the clamp route and worked great. Check the PCV valve make sure its not clogged or sticking. That is what i did and it fixed code 25 Idle air circut low or high or leak in vaccum hoses. It also fixed code 24 throttle position sensor low/high. Mine was brand new so i know there was nothing wrong with it. It also fixed my car jerking when i would hit the gas. Made it not be sluggesh as well. No poblems now on take off when hitting it and up a hill. Runs like new again. Well like new for it being a neon. Good luck and hope this helps some people.
Old 02-18-2005, 12:11 AM
Re: Idle Control and PCV Hoses/Valve fixed here is how to do it. Got Spudder and jerking?
Also check the EGR system. Make sure its nice and tight on there.
