Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 02-11-2005, 12:17 PM
Mike75 Mike75 is offline
Headlight problems
Okay, I'm taking the day off work since my headlights started cutting out while driving in the dark in the pouring rain in busy Los Angeles traffic. Here are the symptoms and what I've checked.
- lights flicker off and on at no steady rate
- only headlights flicker - not the tail lights, nor front parking lights
- I have checked all fuses under the hood, and under the dash panel
- lights flicker in unison (right and left go off and on at the same time)
- both high and low beams affected
- problem persists even when car is sitting perfectly still
- car had driven approximately 30 miles at +/- 50mph before this started
- the voltage meter on my instrument cluster stays constant (no fluctuating)
- if I turn the lights off for awhile, then turn them on again, it takes awhile for them to start flickering, but it gets dramatically worse the longer I keep them on
Sound like it could be a relay? Or the alternator/battery? I want to rule out the alt/bat since it seems that I would have fluctuations in other lights/electrical components if this were the case...but I'm not sure. I really need some help here.
Thanks in advance!
Old 02-11-2005, 03:52 PM
philrogers philrogers is offline
Send a message via AIM to philrogers
Re: Headlight problems
Replace the headlight switch. I had the same problem with my Ranchero recently.
Old 02-11-2005, 08:18 PM
Awesome. Thanks dude.
Old 02-11-2005, 10:01 PM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
Once again, check with Ford to see if this is covered under a recall and if it is see if the recall has been done. If it is and has not and you simply replace the headlight switch with one from Joe Schmo's parts house it will happen again.
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 02-13-2005, 12:13 PM
heeheehee
Thanks guys.
http://www.alldata.com/TSB/19/93190711.html
Damn good call. You both just saved me some cash, which seems to be in seriously short supply around here.
