Old 02-11-2005, 10:42 AM
cubanlorenzo cubanlorenzo is offline
Send a message via AIM to cubanlorenzo
95 putting
95 blazer 4X4 "W" LS. yesterday i went out to start the car because it was 27 degrees out. 5-7 mins later i went outside and the temp guage was at a quater. so i drove away. as i drove away my car was putting. the SES light didnt come on but i turned around and plugged the scanner in anyways and nothing came up.. what do you think?? i also recently did a full tune-up
Old 02-11-2005, 12:37 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Re: 95 putting
I assume that after 5-7 minutes you used to be at Temp. Did you ever get up to normal operating temp? I am thinking you have a stuck open thermostat for starters. Hows your coolant level? Does the heater work?
Old 02-11-2005, 02:28 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 95 putting
27f or 27c?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-11-2005, 02:50 PM
Re: 95 putting
27F. coolant level if fine, heater works great, maybe a little too great. really hot heat.
Old 02-11-2005, 03:38 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: 95 putting
So you were expecting the engine to warm up completely in 5-7 minutes?
Old 02-11-2005, 11:14 PM
Big Tall Dumb Ass
Re: Re: Re: 95 putting
That's what I was thinking, 5-7 Minutes isn't long enough to get to temp, but then, since it rarely gets to 27° F in Phoenix, I didn't want to question it. Back to my original question, did you ever get to normal operating temp? If so, did the sputtering stop?
Old 02-11-2005, 11:38 PM
Re: 95 putting
no, that isnt it at all. i know the engine wouldnt get up to temp in 6 mins, im just saying that i got into it and started to drive it at 6 mins. getting up to temp has nothing to do with my problem. it is when i started to drive away, my car was putting. all the way up the road. it has never done this before. that is what i am asking, about the putting...
Old 02-11-2005, 11:52 PM
BlazerLT's Avatar
AF -Advisor
Re: 95 putting
Check your EGR.
Old 02-14-2005, 07:30 AM
Big Tall Dumb Ass
Re: Re: 95 putting
Did the sputtering ever stop when you did reach operating temp? If so, I would think the problem is being caused by a rich mixture condition. Any Check engine light?
Old 02-14-2005, 10:24 AM
Re: 95 putting
no check engine light. i went home and tried to use the scanner and see if anything came up. nothing came up. after i un plugged the scanner, i started the car and went for a drive again and everything was smooth as it was before. i did check my egr valve and it was clean as a whistle.
