Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 02-11-2005, 09:45 AM
SKEETS44 SKEETS44 is offline
Angry Radio In Safe Mode
Radio Is Stuck In Safe Mode Any Help On Finding A Codes To Fix It I Do Not Have Manual
I RECENTLY HAD A TUNE-UP DONE THE RADIO WORKED WHEN I TURNED
IT ON WHILE HOLDING MODE BUT THEN OFF EVERY 10 MIN NOW IT WONT GO ON AT ALL .
Old 02-11-2005, 05:03 PM
boschmann boschmann is offline
Re: Radio In Safe Mode
Is it displaying safe or is it dead? If you don't have the code you can only hope someone wrote it on the radio itself. Otherwise you have to get the serial # off the radio & the VIN of the car & take to VW. Most dealers now charge for the code.
Old 02-11-2005, 08:22 PM
Safe
No It Says Safe Accross The Radio Display
I Guess I Just Must Search For The Damn Book My Mother In Law Was The Original Owner So Hopefully We Can Find It Any Ideas Let Me Know Thanks
Old 03-06-2005, 11:16 AM
herbster herbster is offline
Unhappy Re: Re: Radio In Safe Mode
I have the same problem as SKEETS44, except I'm lucky enough to have the unlock code. Now my problem is, how do you enter the code?
I tried using the hh:mm setting of the clock (as someone told me), but that doesn't do the trick. Any help would be appreciated.
Old 03-06-2005, 04:36 PM
You press the seek & scan or mode & scan, depending on which radio you have, at the same time for a couple seconds. The display should then go to 1000. Each of the radio preset buttons #1-#4 control the digit in that place. Push the presets so that your code is displayed then press the seek & scan or mode & scan again. The radio should turn on.
Old 05-20-2006, 04:34 PM
hakebros hakebros is offline
Yes, that's the procedure but I only get 2 tries and it'll lock out for 1 hour .
I'm trying to find the code for #VWZ5XB581732 The radio is made by Mitsushita for VW and model #357035180AX
Old 08-18-2006, 05:14 PM
took the radio out and found the code written on the radio itself... a different code than what was written in the owners manual...all okay but now I want to replace it with a cd player.
For $2. bought a program off ebay which lists hundreds of codes for many radios but not mine. They say the program covers 90% of most radios & I believe it.
If you need a code, email me and I'll see if it is listed.
Old 09-07-2006, 11:33 PM
rager099 rager099 is offline
i need a listing for the 96 jetta gls radio code? pls
