Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 02-11-2005, 05:25 AM
Jungleman Jungleman is offline
Angry Sluggish Engine
Guys,
I noticed that my engine is sluggish in the mornings, ie when i hit the gas pedal it take a while for the car to respond, as if it wants to stall, what could the problem be?
I also noticed that my fuel consumption has go up, i have changed the O2 sensor with a new bosch type.
Rgds
Jungleman
Old 02-11-2005, 08:46 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Sluggish Engine
1994
I think you have a rubber dust boot on your accelerator cable in the engine that after awhile starts to breakdown and gum up the cable that starts to make it sticky.
This could also be caused my dirty fuel injectors (add a can of injector cleaner to the tank, be carefull if this is your first time since it can losen up junk in the tank and clog the fuel filter).
As for poor MPG, check your tire pressure and wait for warmer weather.
-Ryan
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 02-12-2005, 10:22 AM
rodeo02 rodeo02 is offline
Some possiblities:
1) Dirty MAF sensor.
2) Bad MAP sensor (dont remember is this year reads manifold press. or not)
3) O2 sensor still not right.
4) Dirty airfilter, intake?
5) EGR stuck open.
6) Really bad spark plugs, wires.
Check that cable boot like Ryan says & grease it with SILICONE grease if needed!
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 02-12-2005, 11:01 AM
JSEY JSEY is offline
Re: Sluggish Engine
My 1996 Trooper will not start.. Has new starter and battery. What could be causing this?
Old 02-14-2005, 02:00 AM
Re: Sluggish Engine
Originally Posted by Jungleman
Guys,
Rgds
Jungleman
This condition improves when the engine warms up a bit.
I have clean up the air filter and the consumption has improved a bit.
Rgds
JM
