Old 02-11-2005, 03:07 AM
macder macder is offline
Send a message via MSN to macder
Question Radiator question: Is this normal?
Ok, now I know that my radiator has lost it's capacity due to limestone build up, and has now began to leak in a few spots. But what is somewhat wierd to me is that my tempature gauge is right before half, but when the car is @ a stand still, im getting lots of steam from the front. Could this be just steam out of the rad in the cracked spots or is my temp guage screwed?
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 02-11-2005, 06:00 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Radiator question: Is this normal?
Unoikely to be the guage, unless there is also some buildup on the sender perhaps. I wouldnt even bother to analyze this problem too much though, but thats just me I'd just get a replacement radiator. I forget the brand, but you can get a decent new radiator for ~100 bucks. A radiator is one part on the car that abosultely has to work properly. The whole cooling system really. It's right up there with the other things that you can't do without like brakes, steering, etc
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
