Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 02-11-2005, 02:39 AM
VenomJetta VenomJetta is offline
Send a message via AIM to VenomJetta
94 Jetta stalling problem
I got a 94 Jetta, starts fine, runs fine, but it stalls out of nowhere all the time. The car won't make a sound, no shaking, the engine just stops and you won't know it till you try giving it gas. I checked the mass air flow sensor, and cleaned it, ran alright for a bit, then stalled. Any help would be greatly appreciated.
Old 02-11-2005, 03:11 AM
I should probably also mention the Jetta is an automatic transmission, 2.0L 4 cyclinder engine, and I recently put a new starter two days before it started stalling, from what I can tell the start isn't the problem though. Once again any help would be grand.
Old 02-11-2005, 05:04 PM
boschmann boschmann is offline
Re: 94 Jetta stalling problem
Does it only stall at idle or will it quit while your foot is on the gas.
Old 02-11-2005, 08:05 PM
both, whether I'm giving gas or sitting at a light. The rpms just drop to nothing, and the power steering goes out.
Old 02-13-2005, 05:20 PM
That can be difficult to figure out, especially since it probably starts back up. Most likely causes include the electrical connection at the distributor, the ECM power supply relay and fuel pump relay. You need to determine if it is loosing fuel or spark, which can be difficult w/intermittent problems.
Old 02-15-2005, 12:22 AM
I got it, it's a loose connection in the fuse box, kinda figured it out on a fluke, I was driving and it stalled and I noticed the clock resets, so then when it would stall I'd kick the fuse box and it would go again. Of course this won't last forever so I gotta get a new box. I appreciate the input though, thank you.
Old 07-14-2005, 01:59 PM
halfpint halfpint is offline
Angry 94 Jetta stalling
I have a similar problem with my Jetta which is driving me crazy!! Any help would be greatly appreciated. My car starts and runs fine until it warms up, and come to a stop. After this, it will miss at highway speeds, and sometimes stall at WOT just like you turn the key off. I drive this car 60 miles to work everyday, and it runs great until I get almost home and stop at a stoplight. If I never have to stop, it will never give me problems. I have found out that when it starts missing, it quits when I accellerate or slow down. It will continue to miss at 55-65 MPH for the rest of the day. If I shift into neutral (auto trany) and turn the key off, and back on while driving, the miss will go away until I stop again. I can always tell when it is going to start giving me problems because it hesitates afert stopping. No hesitation=no problems. I did find a broken breather pipe from the front of the block to the valve on the valvecover and fixed it, but it didn't help. This car has 265k miles on it and has never had any problems until now.
Old 07-27-2005, 05:02 PM
pcashford pcashford is offline
I joined this forum because of similar problems with my daughter's 94 Jetta. Currently we are having problems with the oil light and alarm going off repeatedly, even though both oil pressure switches have been replaced. The car stalls. The engine also surges intermittently. I will have my mechanic check what has already been suggested. Any other suggestions? I'm a frustrated mom!
Old 08-05-2005, 06:56 PM
Waterguy Waterguy is offline
94 Jetta iginition problems etc
Well, I've read so many threads on Jetta III starting problems etc. My daughter just bought a problem Jetta from this very sly guy. Next Day the car wouldn't start. I replaced all the relays on the fuse panel, fuel pump relay, ECU relay, etc. No problem since then. Starts every time.
Old 10-07-2005, 11:21 AM
create38 create38 is offline
halfpint
it could be a crank sensor problem
Old 10-11-2005, 08:59 PM
3green 3green is offline
I can help I have had this problem too!! First they replaced the ignition (key part) then the a temp prob.. No Luck!! then all the spark plugs and wires!!No luck Finaly I let them have the car for over a week. they finaly got it to fail on them at the shop and they found that the engine speed sencer prob. had a fault!! they replace that $80 + labor and the car does'nt stall on me while im driving anymore out of the blue.. I hope this helps!! good luck,
Old 10-13-2005, 11:57 AM
jellybellyjean jellybellyjean is offline
All the problems above pretty much describe my 94 Jetta too. I am going to try fixing all those things and hopefully that will help mine. Seems to be a common problem in 94 Jettas
