Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 03-17-2002, 10:12 PM
custom86Lx-i custom86Lx-i is offline
nitrous on B16A
ok all i need to know is should i start out with a 75 shot or drop it to a 50 shot and leave it. also can i buy some NOS fuel solenoids to turn my dry NOS kit into a wet kit or just sell my kit and buy a wet kit. my kit is the NOS brand 5100 universal dry manifold kit.:bandit: :smoka: :smoker: :smoker2:
peace out
Interior:
gutted except the dash , painted with a
truck bed liner , carbon fiber shifter, E-Brake handle and pedals
Exterior:
none yet but stripped mouldings and black steel rims.
Performance:
B16A swap, Cam Gears, race spec pulley (no accesories), ACTstageIIclutch, CTR valve cover, DCsport 4-1 one piece headers, Magnecor race wires, NGK plugs
crane distributor upgrade, MSD 6A ignition, Custom intake with K&N filter
,Custom Ram air, New radiator, new stock fuel pump with a HOLLEY in-line, AEM FuelRail with B&M Regulator, Accel 30Lb injectors, 75 shot N2O, MUGEN ECU chip
Suspension:
Tokico blues with sprint 2.25" springs
lude A-arms "camber kit" in front
ingalls rear camber kit in back
no strut bars yet
no wheels
Old 03-18-2002, 08:53 AM
MD99SiR's Avatar
MD99SiR MD99SiR is offline
Send a message via AIM to MD99SiR
If your new to Nitrous your best bet is to start out at the lowest possible shot ie:25 and work your way up depending on your ability to shift and once you get used to spraying. You wouldn't want to start at a 75 and end up picking up your engine with a broom all cause you were NOS happy. Start low and work your way up, check your plugs to make sure it is running correctly and then bump it up to a 50 shot. Your engine can handle a 50 shot no prob. When you get to a 75 you might want to be more careful or start saving up for internals or a new engine. Hope this helps. Peace
99 Civic SiR
Greddy EVO
AEM CAI
Sportline Springs
17" Enkei RS7 rims in Bronze
Nitto Neo Gen 205/40/17 tires
Red Carbon Fiber Hood
NX kit 35 shot for now, going to up it to a 50
Sparco Black/Red Torrino Racing Seat
20% Window and sunroof tint
Old 03-18-2002, 10:22 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
HE can start the 75 shot. I mean u don't have to start from 25? Its all about patience and how u use it. Anything above 60 shot u HAVE TO upgrade ur fuel pump and fuel rail. Its nice to get some upgrade fuel injectors also. My friend used a 60 shot on his ' 00 si and he blew up the engine cause his fuel pump failed. SO if you have an up graded fuel then u should be fine. So correct me if i'm wrong anyone..cause i'm pretty sure thats what needs to be done to run 75 shot safely.
