Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 02-11-2005, 01:22 AM
mixdamike mixdamike is offline
Send a message via AIM to mixdamike
Custom speaker box, Looks great, sounds like crap- HELP!!
I just built a custom speaker box for 4 10 inch subs for my 99 cougar. The layout inside the box consists of 4 squares individually sealed. I only have two subs in it right now, and im waiting to cut out the holes for the other two when i get them.
The prefab box i had originally, hit really hard. The new one doesnt sound so great, actually sounds like crap, But looks awesome. I only enlarged the size of the box by a couple of inches per speaker not thinking it would be a big difference. I was wrong! The only options i can think of are: Putting something inside the box to cut down on air space for each speaker, or tearing the box down trying to salvage as much MDF as possible and building a new one that doesnt look as good. What can i do?
Thanks
Mixdamike
Old 02-13-2005, 01:07 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
I dont really know much about sub boxes, but it is just more than building a box and putting subs in it. There is actually a science to the whole thing of how the waves inside the box travel. Btw, are you sure your wires are hooked up to your subs/amp correct?
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 02-13-2005, 08:02 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: Custom speaker box, Looks great, sounds like crap- HELP!!
Yep, you can't just get some 1/4" plywood and go to work. I use 3/4" HDF and 1" to 1 1/4" HDF for extremely powerfull systems. Do you know what volume of air the subs needed and what you ended up with? What material did you use and how did you put it together. I usually use Liquid Nails and screw the sides together about one every 2-3" apart.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
