| Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music. |
Hey all,
I've got some questions about wiring up a single amp with a second battery. Here's a quick diagram: ![]() Do you see anything wrong with this, and what do you think about the diode idea to eliminate chassis current noise? I don't know if diodes exist that can take the kind of current loads that go through the grounding wire, but I'd like to look into it. |
Re: Wiring questions
Hmm...i'm not seeing the diagram show up...
NG |
that's odd... My computer seems to be serving the images just fine... you my try clicking here and see if you can access it manually. If you still can't see it, I'll try rebooting my computer to reset the server. Sometimes my ISP drops our connection too, and you might have been trying when my connection was out.
Re: Re: Wiring questions
host it for free on www.imageshack.us Use one of the links that says "for forums" and it'll post the pick in here... NG |
Ya not seein anything either, but i dont fully understand what you are trying to say. Wiring up an amp to a second battery? if your talkin bout something that simple (wich i doubt) wire it the same you would with the battery under your hood, run each battery parallel
300amp excessive amperage Alpine H/U- Incriminator Audio 20.1 @.35 (2) 15" Q's 8 cubes after 80sqin. 28hz CDT EF-61's Profile AP1040 on comps NSB-100
NG |
I run a Yellow Top under the hood, and a basic Everlast battery in the trunk, if you do a similar setup just make sure you dont run your system with your car off an try to keep the batteries fully charged.
Well, I know the one under the hood is a stock honda battery, and the secondary will be an older battery from my Dad's Ford Ranger. I also seriously doubt I'll be using the system at high power for extended periods of time. There isn't much of a community in my town that appreciates this sort of thing (think lots of old ladies).
Does anyone know what a diode is anyway? You seemed to miss that idea completely. I read on one of the basic car audio sites about how problems with back current causing noise in the system when the brake lights turn on, and I thought that since diodes are designed to allow current to only flow in one direction, they would be the ideal solution to keeping grounding noise out completely. The only problem is the only diodes I've ever seen are on like 25 gauge wire, and could never handle the current. Does anyone know if diodes big enough even exist? Last edited by Diceman83; 02-11-2005 at 09:42 PM. |
NG |
Silverado Ext. Cab 4x4 z71 Pioneer 4900mp Orion P6.2 Componet sets front Orion C63 Coax rear DirectedVideo 9" all in one DVD with surround 2007 SATURN OUTLOOK AWD XR with full entertainment package |
Re: Re: Re: Wiring questions
That diagram looks ok, but dont cut into those power and ground wires. Use terminals off of the battery
yea poncho wtf are u talkin about?
2002 Ford Explorer Limited D31 yellow top Kenwood DDX-7017 2 Ascendant Audio Avalanche 18's 13 cuft NET ported box tuned to 27hz Autotek Mean Machine MX3000.1 Ascendant Audio Arco component set Orion 275SX (Mids) PPI Art Series A200 (tweets) Poly Mids for rear fill to come soon. |
