Old 02-10-2005, 09:17 PM
kingpinn's Avatar
kingpinn kingpinn is offline
ecu+vafc
ok i askd you guys about the p28 ecu for a d16z6 swap in a rex 91 si and you said yes. so now i know what to get, but then i heard that if i get vafc that i can use the stock ecu ... so simple, that answered my question. but wait theres more someone else said still get the p28 ecu because it will be faster because it is the ecu from the d16z6 and its programed for the z6 so more fuel and air to the motor. But I thought that I could control that with the vafc... HELP
Old 02-10-2005, 09:56 PM
honda_luvr_2000 honda_luvr_2000 is offline
Re: ecu+vafc
u can't control the air w/ any computer, only the fuel. u'r stock Si ecu will work perfectly fine w/ the V-AFC. u'll be able to do better fuel management if u go that route, instead of buying a set program in a p28. i'm going the same way, because i didn't want to convert to odbII (i'm building a y7/y8 for my 88 dx rex)
Old 02-10-2005, 10:02 PM
kingpinn's Avatar
Re: ecu+vafc
thanks
Old 02-10-2005, 10:15 PM
quiXilver's Avatar
quiXilver quiXilver is offline
Send a message via ICQ to quiXilver Send a message via AIM to quiXilver Send a message via Yahoo to quiXilver
Re: ecu+vafc
get the 88-89 integra pg7 i think it is, better fuel maps.
http://www.cardomain.com/quixilver09
B18A
-It's always somethin'
Old 02-10-2005, 10:23 PM
Re: ecu+vafc
not to be an ass, but wut's the point of better fuel maps if u'r running a fuel controller? yes the pg7 runs richer than the pm6, but if u r running a V-AFC then u can change the map completely.
however one thing the pg7 would help out, it raises the rev limiter to 7500.
Old 02-10-2005, 11:22 PM
quiXilver's Avatar
Re: Re: ecu+vafc
oops lol that's what i meant,
I knew there was a reason I got it for my mini-me
I stand corrected.
B18A
Old 02-11-2005, 12:20 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
Re: ecu+vafc
convert to OBD1 and get the P28. You will be happier in the end.
Your sohc vtec motor will run much better than with a pm6 or pg7 with a vtec controller. If you want to go that route to just have a "cool vtec controller" just get the vtec controller along with going OBD1 and with the P28 then get it dyno tuned.
I used to have a d16z6 si hatch and it was slow as balls. it was controlled by a pm6 and vtec controller, I wish I would have went OBD1.
2002 Acura TL Type S
1991 Honda Crx Si
Old 02-11-2005, 04:06 PM
kingpinn's Avatar
Re: ecu+vafc
so i should still get the p28?
civicHBsi91 this scares me is the d16z6 a bad swap because i dont want to be slow as balls as you put it . and i would love to get a b16a2 or b18c5 but i have the money for that so is there a better swap for the same money say around 700 dollars and the has to be lots of parts out for it thanks
Old 02-11-2005, 04:40 PM
Re: ecu+vafc
the z6 is good if your car is lighter, some guys hit low 14's with hf's all gutted and stuff but most heavier cars are slower...
my z6 hatch probably would have hit high 15's at best...
1991 Honda Crx Si
Old 02-11-2005, 09:30 PM
kingpinn's Avatar
Re: ecu+vafc
with just a d16z6 in an otherwise stock 91si with a vafc what do you think i could pull well you dont know my drivin skill so lets say you drivin it what could you run 1/4mile
thanks
Old 02-11-2005, 10:02 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
I think even with a great driver, low 15's would be the fastest et youd probly see.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 02-11-2005, 10:39 PM
Re: ecu+vafc
15's to 16's...
1991 Honda Crx Si
Old 02-11-2005, 11:51 PM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
Re: ecu+vafc
Stock D16z6 with a P28 will run low 15's to high 14's depending on how much weight has been removed from the car. If your running 16's you have major problems or you need to get a gokart with a centrifugal clutch. P28 is the only eay to go if you want your car to get good gas and preform the best.
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
Old 02-12-2005, 07:53 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: ecu+vafc
n: obd0 with vafc
just do it right and convert to obd1. Then you could get the vafc if youd like.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 02-12-2005, 04:18 PM
kingpinn's Avatar
Re: ecu+vafc
thanks guys im kinda hoping for like a 15.7 or lower and i say 15.7 because thats what my lude ran an i dont what a slower car then what im selling. and i dont think a 15.7 is to much to ask for with that set up..... thanks guys
