Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 02-10-2005, 07:57 PM
s13dr1fter s13dr1fter is offline
Send a message via AIM to s13dr1fter Send a message via MSN to s13dr1fter
clutch problem
I'm having problems with my clutch. It has no pressure and we been bleeding the line like crazy. Well i start to get pressure if i don't bring the pedal all the way to the top. But then when i bring the pedal to the top i lose all pressure. Does anyone by chance know what the problem is? I got a new slave cylinder if that helps any and this car has been sittin for quite some time now.
Old 02-10-2005, 08:06 PM
sidewayzS13's Avatar
sidewayzS13 sidewayzS13 is offline
doin it sidewayz
Send a message via AIM to sidewayzS13
Re: clutch problem
ka or sr?
Originally Posted by Muscletang
I say let it run its course. Most women experiment with things. They'll try something whether it's mind altering drugs, going down on their best friend, an Emo song, or plastic surgery.
Old 02-10-2005, 08:08 PM
Re: clutch problem
sorry its a ka24de
Old 02-10-2005, 08:31 PM
D-Bo's Avatar
D-Bo D-Bo is offline
Re: clutch problem
did you bleed it till the slave cylinder was empty? i think thats a problem nissanfanatic had that took away pressure from the lines
Originally Posted by iVteC_PoWeR
to me when i really look at it hondas just too expensive and theres not much power even after you spend loads of money...
http://www.cardomain.com/id/dbo240
***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE***
Old 02-10-2005, 08:35 PM
Re: clutch problem
I bled it till the master cylinder was empty.
Old 02-10-2005, 08:42 PM
D-Bo's Avatar
Re: clutch problem
i'm not sure which cylinder it was you shouldn't be fully bleeding, or even if its the fact that its not supposed to be fully bled or not.. forget it, i'll wait for someone else to get it right
Old 02-10-2005, 09:10 PM
Re: clutch problem
alright but i believe the cylinder by the tranny is the slave and the master is by the back driver side corner.
Old 02-10-2005, 09:14 PM
john.doe john.doe is offline
Banned
Re: Re: clutch problem
Originally Posted by sidewayzS13
ka or sr?
Is that relevant?
Old 02-11-2005, 12:19 AM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Re: clutch problem
Yea if you bled it until no more fluid came out, you have to push the piston or whatever back. Use an air compressor and pressurize the line going up to the master cylinder. Then make sure you have new fluid in the resovoir before you begin to bleed it again.
BTW, remove that dampener box. Its a big PITA to bleed the system with it on. www.zeroyon.com has a write up.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 02-13-2005, 10:24 PM
Re: clutch problem
where is the dampener box? Is it next to the slave cylinder.
Old 02-13-2005, 10:27 PM
monooxide's Avatar
monooxide monooxide is offline
Banned
Send a message via AIM to monooxide Send a message via MSN to monooxide
man...
I hope i dont have Tranny problems when i swap in my 5Spd...kinda getting me worried...
Old 02-13-2005, 10:30 PM
Re: clutch problem
i don't have any problems its just i can't get the damn pressure to build up. i get fluid from the master to the slave bu still no pressure.
Old 02-13-2005, 11:38 PM
TatII TatII is offline
it shouldn't be that hard to bleed the clutch. i just did it last week when i changed my clutch line. just have your girl friend stomp on it as many times as possible and keep that sucker down, and just losen the bleed screw. and repeat. you have to pump hard and fast though. and always make sure your reservoir is full. when it gets low, air could get in, and you would have to do it all over again.
also another thing to note, if your losing pressure slowly, you could have a leak in the line somewhere. i had a worn out rubber line by the fittings. also the rubber line needs to have a small little brass washer that goes between the line and the slave cylinder. without it, it would not seal. also you need some nice ass line wrenchs to tighten it. when i used my cheap line wrenchs, it would lose pressure also, and i saw leaks. i had to go to my work place and borrow a 200 dollar set of line wrenches, and i tightend the shit out of it, now its good.
if the rubber line is no good, its only 14 dollars at the dealer.
a aftermarket slave cylinder cost 25 bucks ( don't go to autozone cause they're parts number is wrong, they'll give you a slave cylinder that looks nothing like the actual thing )
a aftermarket master cylinder will cost around 40-60 dollars
how do i know the prices? i changed all of them ( they all gave out on me at different times )
303whp stock internal KA-T
94 Acura NSX
Best E.T. 13.559
Best Trap speed 107.62 mph
Old 02-13-2005, 11:53 PM
Re: clutch problem
well i just bought both of the cylinders and when i step on the pedal it just goes to the floor and stays there. i have to manually bring it back up.
Old 02-14-2005, 12:21 AM
yeah, when you first bleed, it expect hte pedal to feel completely dead, and you have to manual use your arm to pump it ( so you can pull the pedal back up ). after like 15-20 pumps, you should feel a faint increase in pressure ( but no where near enough to pop the pedal back up). once you feel that small amount of pressure build up, hold it down, then bleed, and pull the pedal back up,, and keep on repeating till the clutch feels good.
94 Acura NSX
Best E.T. 13.559
