Old 02-10-2005, 07:22 PM
talontsi26 talontsi26 is offline
high idle???
my 93 stealth rt tt is idling very high, when i purchased the car it idled at 1k rpm but recently it began to idle higher and now it sits at 2.5K rpm at idle what could be the problem????
Old 02-10-2005, 07:27 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Re: high idle???
Wow thats a very high idle, might want to check the throttle body and idle controll valve. Does it do it when its fully warmed up even?
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 02-10-2005, 07:42 PM
PoorLuder PoorLuder is offline
Re: high idle???
You will want to check for a vacuum leak. I had a similar problem when I put an intake on my lude because I stopped up one of the sensors. Normally though, it means that you are losing pressure in the cables that run to the throttle body. One of the easier ways to find the leak would be to spray some WD-40 over the hoses and look for where it is being sucked up.
95 Stealth
http://www.cardomain.com/id/stealthsohcer
Old 02-14-2005, 10:29 PM
Nick222 Nick222 is offline
Send a message via AIM to Nick222
when i first start my r\t it idles at about 2k until it warms up.
Old 02-15-2005, 11:24 AM
it idles high even after the car is warmed up, the rpm will bounce from 1 to 1.5 to 1 to 1.5 then it will sit at 2.
Old 02-15-2005, 02:56 PM
Thourun's Avatar
Re: high idle???
Wierd, clean out your throttle body and make shure the vacume lines associated with it are clean also. I think theres a screw on the seft side of hte trhrottle body that helps controll the idle so check that too.
1995 3000GT VR-4
Old 02-15-2005, 04:26 PM
Igovert500's Avatar
blue + red light magnet
Re: high idle???
Erratic idles are typically caused by bad spark plugs, bad o2 sensors, or vacuum leaks...are you getting any check engine lights?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-17-2005, 09:43 PM
Re: high idle???
no check engine light, unfortunately now my car dies at times when i release the gas pedal after a hard acceleration
