Old 02-10-2005, 07:21 PM
spydergst spydergst is offline
Lightbulb Valve Seals?
I have been told on this forum that my valve seals are bad in my GST, wich causes it to smoke after i let it ide for 10-15 min, how serious is this problem.
Old 02-10-2005, 07:24 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Valve Seals?
It will burn some oil, lower your effective octane a bit (knock), and eventually coat the tops of your pistons in a thick layer of shit that will raise compression and cause knock from the hotspots on the pointy parts.
The question isnt how serious it is, rather at what point is it worth it to you to spend the cash to get it fixed. That I can't answer. If this car is just drive around, it may not be worth fixing until you have other work to do at the same time, timing belt for example. If you are trying to make any amount of power with this motor, its going to hurt you and you might as well fix it. YMMV/IMO/IME/etc
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 02-10-2005, 07:33 PM
How much would it cost me to have the valve seals replaced?
Old 02-10-2005, 07:46 PM
AF - Advisor
Re: Valve Seals?
Impossible to say since I do all my own work. It would cost me 20 bucks for the seals, and another 20 perhaps at my favorite machine shop. The rest of the labor would be free. Its basically a head gasket change/tbelt job. I'd say 500-1000 dollars, but hopefully someone has had this done. OR you could just shop around for the best estimate.
Kevin Jewer
Old 02-10-2005, 07:59 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Re: Valve Seals?
I asked mitsu dealer/shop and they want about 1500 for valve job..... I am in the same boat.
I am having jake/eclipseRST rebuild a 6 bolt and install it.
I will be dropping it off on feb 26th and can barely wait. It will cost about $2500 for everything from him....
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 02-10-2005, 08:14 PM
joemathews's Avatar
joemathews joemathews is offline
Re: Valve Seals?
I did ARP head studs, and bought a full engine gasket kit. I only replaced the head gasket and valve stem seals, and of course miscellaneous gaskets like the valve cover gasket, etc. If you can get a friend to help you out, you can do the same thing I did for $200 or so, and have a stronger HG afterwards.
1996 Eagle Talon
