Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 02-10-2005, 06:54 PM
hammer0822 hammer0822 is offline
1999 Olds Intrigue GL Remotes
I bought the car with just one key like almost anyone else in the world. I have a remote from a 1999 Oldsmobile Alero that worked on the car so I know its functioning. Will it work and how do I program it? Thanks
Old 02-12-2005, 07:15 AM
slacker_53's Avatar
slacker_53 slacker_53 is offline
Hammer, I don't believe that the remotes are the same on an Alero. The remotes on your Intrigue should totally different, not only in shape and size, but the part# and FCC# should also be different.
Go to your GM dealer and see if they will give you the part# (take your VIN# with you), then buy them off of Ebay. You should be able to pick them up for $10 a piece, and then the program info is posted on these boards somewhere. You may have to search to find it.
Good luck,
-slacker
When I die, I want to die peacefully in my sleep, just like my grandfather................not yelling and screaming like the other people in his car!
http://www.geocities.com/tbuckit1/index.html
Old 02-12-2005, 12:17 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Re: 1999 Olds Intrigue GL Remotes
98-99 Intrigue remote programming:
With doors closed:
1) Insert Key in ignition and turn to the run position.(do not start the car)
2) Turn key off and take it out of the ignition.
3) with the Driver side door lock switch, hold it in the Unlock position.
4) While holding the Drivers side door lock in the Unlock position, insert Key in ignition, without tunning it on, 3 times. On the third time, leave the key in the ignition.
5) Release the Drivers side door lock switch. You should here three door dings. If you do, this will indicate it is in the Keyless remote programing mode.
6) With your Remote, hold both the Lock and Unlock buttons at the same time untill you hear "two" door dings. This will indicate the remote is programed. (this can take upto 15 seconds) You can program up to 4 remotes while in this mode.
7) To stop keyless remote programing, Take key out of the ignition.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
