Old 02-10-2005, 06:13 PM
77chrome 77chrome is offline
Transmission Oil
How many quarts of transmission oil does the 5 speed hold?
Old 02-10-2005, 07:46 PM
PoorLuder PoorLuder is offline
Re: Transmission Oil
Do you mean total or after you have drained the tranny? The service manual that came with the car should list what the total quarts are (I don't have mine in front of me). However, I am not sure where you find out how much to put in after you have drained the car. I wish I had the answer to that as well.
95 Stealth
http://www.cardomain.com/id/stealthsohcer
Old 02-10-2005, 07:50 PM
sLADe781 sLADe781 is offline
I believe it was about 2.5 quarts so buy 3.
Old 02-10-2005, 07:52 PM
Igovert500's Avatar
blue + red light magnet
Lubricant capacities (from the service manuals)
Manual transaxle [to bottom of filler hole]:
FWD: 2.3 L (2.4 qts)
AWD: 2.4 L (2.5 qts)
Transfer case:
5-speed: 0.27 L (0.29 qts) [1991-1992: 0.43-0.51 inch (11-13 mm) below the filler hole; 1993+: to bottom of filler hole]
6-speed: 0.30 L (0.32 qts) [to bottom of filler hole]
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-10-2005, 09:11 PM
Re: Re: Transmission Oil
Transfer case:
thanks guys I got three quarts of bg syncroshift, think that will be enough for tranny and transfer case?
Old 02-10-2005, 09:14 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
How much was it? Whats the best tranny lube?
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 02-10-2005, 09:24 PM
It was 16 dollars a quart. I got it from 3sx. Its good if you have a tranny that shifts hard. And I hear it cures the problem of bad syncros. Im gonna put it in on saturday ill let you know how it feels.
Old 02-10-2005, 09:41 PM
Thourun's Avatar
Does anyone know how many places in the drivetrain you have to change the lube? How often? And what are the different kinds of lube needed for the different parts?
1995 3000GT VR-4
Old 02-10-2005, 11:26 PM
Igovert500's Avatar
http://www.stealth316.com/2-awddrainfill.htm
This should answer all the questions.
Oh, and I know it's a bit late, but I got Synchromesh at Autozone for $7 a quart.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-10-2005, 11:34 PM
ITS CALLED bg SYNCROSHIFT II
