Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 02-10-2005, 04:41 PM
qdt69 qdt69 is offline
Question tail light terminal
got a new cig lighter that has a light on it, the vague instructions said to hook up the wire for the light to the tail light terminal so it comes on when the lights are turned on, it has a U shaped end to it...
anyone know where the tail light terminal would be?
thanks.
Old 02-13-2005, 08:45 PM
hopeless4life hopeless4life is offline
Send a message via MSN to hopeless4life
Re: tail light terminal
They probably mean tap it on to the park lamp fuse. You best bet is to tap it on to the wire behind the radio, cuz it is closest to the lighter. Take the radio out and in the harness in the back there will be 2 brown wires, one is a speaker wire the other will test 12 volts with the parklights on nothing when they are off (positive polarity) this is the wire you want. tap your cig lighter wire on to it and it should work with the parklights.
Old 02-14-2005, 09:21 AM
thanks, i'll give it a try later and let you know how it goes.
