Old 02-10-2005, 05:28 PM
turbo ES turbo ES is offline
alchohal injection?
can someone explain to me what the alcohal injection and propane injection does. Ive heard a lot about it and its kinda frustrating when you dont know what it is. (i like to think im not as stupid as some of my questions are)
Old 02-10-2005, 06:15 PM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
Re: alchohal injection?
water/alcohol injection is a system that cools down the air inducted into your engine. basically, its a simple system that injects a fine mist of a water/alcohol misture in your air stream to cool down the air. the cooler the air, the more air, which means more fuel and eventually more power.
it also allows a person to raise the boost level on a FI car and runner higher boost without detonation. this is of course if the fuel system can provide enough fuel....
propane injections i will let someone else explain because i dont know too much about it, but i think it may be a diesel engine thing.
ZedEx Crew Member #4
Old 02-10-2005, 07:22 PM
77chrome 77chrome is offline
Re: Re: alchohal injection?
Yeah Propane injection is for diesel trucks. It serves the same purpose nitros does in a gasoline engine.
Old 02-10-2005, 07:55 PM
ok cool thanks
Old 02-10-2005, 09:17 PM
Igovert500's Avatar
blue + red light magnet
Re: Re: Re: alchohal injection?
Nope, nitrous is a power adder...you shoot nitrous, you gain hp. Propane doesn't add hp, it is used to retard early detonation aka knock.
Propane has an octane rating upwards of 110+, when used, it allows you to run higher levels of boost without running too lean. It basically is like running race gas on the street.
It isn't a power adder like nitrous, and it isn't reserved solely for diesels.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-10-2005, 09:58 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Do diesels get early spontaneous combustion too? I know how they work but I've never heard of diesels needing to prevent knock.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 02-10-2005, 11:40 PM
Z Cars Fanatic
yeah they get detonation as does any cumbustion engine but diesel is alot better burner than regular gasoline, especially US gasoline as we get the crap of the crap.
Old 02-11-2005, 02:42 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Modern desiels do not get knock, in fact is imposble for them to get it, however in the diesel world you add fuel to gain power, and add boost to lower EGT's so you dont melt anything.
Alochol/water is used to cool the intake charge, and is done so because of the energy it takes to cover a liquid to a gas.
Propain does not cool the intake, instead it up's the octane and allows for more boost. It is also an extra fuel so it can be used when you are at the limits of your current fuel system, or when you need more octane, however you want to set it up.
My laptop bettery is almost dead or I would go more into detail.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 02-11-2005, 12:23 PM
2old 2old is offline
Re: Re: Re: Re: alchohal injection?
It's not impossible for desiels to knock unless you are talking about direct injection desiels.
The combustion is essentially one controlled knock since the conbustion starts when the air is compressed to the point where it is hot enough to ignite the fuel and therefore does not require a spark plug.
On direct injection desiels the fuel is only added after the air has been compressed so there isn't any fuel to pre-ignite when the air is being compressed (IE before the piston has hit it's highest point).
The rattle you hear in diesel truck engines is actually engine knock.
Just an FYI since we really don't care about this in gasoline cars...
