Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 02-10-2005, 04:05 PM
cdigrazio cdigrazio is offline
Send a message via AIM to cdigrazio Send a message via Yahoo to cdigrazio
2004 intrepid starter makes grinding noise during start
I have a 2004 Intrepid that makes a high pitched spinning/grinding noise during a normal start. This is intermittent, about once every two weeks. and happens on cold morings. I had the dealer replace the starter, and load check the battery. I also replaced the starter relay. Any ideas?
Old 02-10-2005, 04:20 PM
A. Souphound A. Souphound is offline
Re: 2004 intrepid starter makes grinding noise during start
Worn ring gear/teeth missing?
Alvin
Old 02-11-2005, 04:44 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
that's very unusual for a ring gear to go bad on a car just barely a year old, although it has happened. I believe that you need to get shims put in place between the transmission and the starter. Sounds like when the bendix disengages, it's rubbing against the moving driveplate. Go back to your dealer and let them take a look at that, since it's an '04 and less than 36,000 miles, it's still under warranty.
Old 02-11-2005, 03:26 PM
lennyr lennyr is offline
I have a 04 intrepid 2.7 with the same problem. Have not got it looked at yet. Started happening with the cold weather. Was going to replace the starter on mine. Please explain the shims?
Old 02-11-2005, 06:15 PM
The shims are thin metal spacers used to do just that; add extra space or clearance between two moving parts. Shims come in different sizes and thickness. If you run into a situation where the starter bendix is rubbing against the driveplate right after start-up, that shim will give extra clearance to avoid the bendix and driveplate from clashing after the engine's been started up.
