Old 02-10-2005, 03:30 PM
97TaurusGuy's Avatar
97TaurusGuy 97TaurusGuy is offline
Send a message via AIM to 97TaurusGuy
Keyless programming instructions
I have a 1996 Windstar GL. I am trying to program a remote to this vehicle. First of all, how can I tell if this van even has the keyless entry system?? And if it does, how do I program it?? I have read many posts that state to try the normal Ford approach, turn the key 8 or so times, and this method did not work. I have read that behind the glovebox there is a input that has to be momentarily shorted but I do not see anything that looks like a type of input. Please describe this procedure to me as if I were a two year old (lol). I have programmed other vehicles in the past with the key method but not familiar with this other method, Thanks!
Old 02-12-2005, 11:28 AM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Re: Keyless programming instructions
Turn ignition to RUN or ACC. Momentarily jump pins in programming connector behind the glovebox. All doors will lock then unlock to confirm programming mode. Press any button on 1st transmitter. Door locks will cycle to confirm programming. Press any button on 2nd transmitter (up to 4 transmitters total possible). Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 02-12-2005, 01:22 PM
Thats my problem I dont know what you mean by te programming connector. I dont see anything behind the glovebox that looks like a connector. Is there a picture of this in the Haynes manual or can you tell me what I should be looking for??? Thanks~~
Old 02-13-2005, 01:20 AM
Onblsht's Avatar
Authorized Vendor
Here is a picture of the same connector, but as found on the Bronco models. This will at least give you an idea of what to look for behind the glovebox: (inside green circle)
Old 02-13-2005, 11:39 AM
Re: Re: Keyless programming instructions
Thanks for the picture. I guess my van just doesnt have keyless entry, I dont have any connectors like that behind my glovebox.
Old 01-24-2014, 12:31 PM
fordyota fordyota is offline
Hey 97Taurus Guy, would you happen to have the picture of the connector that ONblsht sent you? I am trying to find this on my 97 Windstar and they should be the same. The picture int he post above I cannot click it.
