Old 03-17-2002, 07:10 PM
ex2fast4u ex2fast4u is offline
Send a message via AIM to ex2fast4u
Which Struts? PLEASE HELP!!
Ok I need new struts now. Before I put on my skunk2's I need to know what kind I should buy. Here are my options:
Tokiko nonadjustable = $69/ea
Kyb adjustables = 109/ex (quoted from my local shop)
or something else if any of you have any other suggestions. I want a good ride. I travel both city streets and the highway all the time. So. Ideas opinions, all that shat. Thanks guys!
*Chris
Old 03-17-2002, 07:28 PM
1995HondaCivic's Avatar
1995HondaCivic 1995HondaCivic is offline
Send a message via AIM to 1995HondaCivic
with skunk 2s i dont think you can have adjustable struts. you need regular springs for adjustable struts
i believe they have to be springs with a 1.8" drop for adjustable shocks
Old 03-17-2002, 08:44 PM
ok, then that makes life a lot easier. The guys at the store must be bigger morons than i thought.
Old 03-17-2002, 09:16 PM
1993HondaCivic 1993HondaCivic is offline
you could have coilover sleeves and adjustable shocks, but it'd be screwed up because you would have two ways to adjust height, but with a spring/ height adjustable shock combo, you better get about a 2'' lowering spring if you want it pretty low. because you wont be able to lower it that much just with the shocks.
Old 03-17-2002, 09:42 PM
praxis praxis is offline
An adjustable shock does not adjust the ride height...it adjust the ride quality and performance. Low setting = nice ride, not as stiff...High setting = hard ride, very stiff.
I have not heard of an adjustable shock/strut adjusting ride height (correct me if I am wrong).
e-mail me for prices.
PraxisPerformanceAutoworks LLC High performance autoparts & accessories.
________________________
sales and specials...Konig wheels, Accmat carpets, Thermal exhaust, DragunFire mufflers
_____________________________
PraxisForums...informative information
PraxisRacing is sponsoring. click for more info.
see PureHonda in its original colors-->
Old 03-17-2002, 09:44 PM
size] [/b]
koni yellows
Old 03-17-2002, 10:13 PM
koni yellow are hella expensive. So whats the final verdict, I am only dropping it far enough to get rid of the gap between the tires and the fender. So do i really need adjustable or just go with tokiko nonadjustables.
Old 03-17-2002, 11:26 PM
strykrcvcc strykrcvcc is offline
whaat tha?
sorry but I think you are getting bad advice.
Praxis is right about shocks not adjusting ride height. not even koni sport {yellow} is capable of this. this can be easily verified at wholehyper.com check under susp. catagory
also you did not say whether you have adjustale coilovers or lowering springs as skunk 2 makes both.
you will be able to use adjustable shocks with any spring or coilover setup as shocks DO NOT ADJUST RIDE HEIGHT.
to get rid of fender gap, i would go with KYB Agx's ($320 on groupbuycenter) and either eibach prokit or neuspeed sport springs. just springs not coilover. those shocks have adjustable damper, not height. good combo there
Old 03-17-2002, 11:28 PM
Re: whaat tha?
would someone else please tell these guys that koni yellow's are height adjustable, obviously they dont believe me
Old 03-17-2002, 11:36 PM
Cool my opinion
Do you street race? If you do I would get adjustable shocks and struts. If this is strickly a daily driver i would stick to a non adjustable setup.
you can never go wrong with TOKICO. around 70 bucks a piece. or adjustables for about 110 each you get what you pay for. I know you will be satisfied with them because I myself have experienced both.
if you want to spend a little more money I have heard nothing but good things about koni sports the yellow series. do not pay more than 140 a piece for these though.
good luck
Old 03-17-2002, 11:39 PM
Re: my opinion
this is only partialy true. you can go wrong with tokico if you plan on lowering 2'' or more
Old 03-18-2002, 08:51 AM
I am not looking to slam my car to the ground. I already have the skunk 2 adjustable coilovers. I know struts and shocks don't adjust height. I am just wondering if the adjustables will make that big a differece. I do street race, and i do attend the drags from time to time, and in the very near future I will be putting the buddyclub kit on my car. So i ask which should I go with: Tokiko non adjustables or KYB adjustables.
Old 03-18-2002, 09:45 AM
i give up
