| Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs |
Has anyone tried this?
I am reading 'Shifting into 4WD' by Harry Lewellyn (recommended) and he mentions that some SUV's with auto transmission can shift into reverse for going forward down steep sections. I immediately went to a local 14% grade and yes - it seemed to work. I went VERY slowly forward but could only test it for a short distance and 14% is not that steep for 4x4'ing.
Has anyone done this on steep sections? Results? Any thoughts - good idea or bad idea? Toy Man |
When I was a teenager I tried shift into reverse while going forward in my parents Toyota.
Wow what a horrible sound that was.
I've never done that but I understand how it would work.
It's letting the torque converter take up most of the stress and the tranny clutches do the rest. If its for a short time then there won't be any damage, BUT that's alot of stress I don't want to put a delicate instrument through. The Xterra has a good crawl ratio in 4Lo and 1st gear and the brakes can keep you from going to fast on the REALLY steep downhills. So you might as well do it the old fasioned way. When I get money I'm going to get the Calmini Transfer case gears to make the crawl ration even better.
-Dustin 2000 Nissan Xterra XE, Sport Package, 4X4, Automatic. And yes its better than yours. |
I would like a set myself, probably get those before lockers, but I don't want to be the first one.
Regards, Ian |
Real men drive stickshift......
Beernuts ! |
Lockers
If you want to drive off-road, this is the BEST use of your money. It is hard to convey the difference lockers make. Lockers would be the first mod installed on my X if I was starting over. No wait - the second mod. First would be rock sliderz because lockers will take you 'in harm's way'. IE., they will take you places you would not even think of going without them. |
I've never tried this while wheeling, but I often times use this same technique while launching a boat. Actually, this is how my father taught me to do it. Basically, keep the vehicle in a forward gear while backing down the ramp with a boat. That way, if the brakes go out, you can use the engine to stop the vehicle.
This should also work wheeling. However, I drive a manual tranny, so I can't test it out for you.. Cliff |
I've neglected to shift out of D1-lo after failing to climb a hill, and proceeded to roll back down (on the brakes) and every time it kills the engine. Have to shift into reverse or it dies.
Brent |
Re: Lockers
I would still rather get the low gearing before an ARB locker. I don't know if you guys have standard transmissions, but the clutch continues to be a weak spot in the Xterra. With the lower gearing I would reduce wear on the clutch. Also with lower gearing I would be using it ALL the time that I'm out wheeling (less stress on the drivetrain, more control from being able to drive slower, etc). A locker is used in certain difficult situations, but you don't benefit from it in 95% of your offroading. If I tended to be out alone a lot, I would get one, because being stuck would be very bad. But I never wheel alone, and I'm almost always out with our club. We have lots of stock vehicles in our club, so there isn't much advantage in me having a truck that can go places the rest can't follow. Because of that we plan our trail rides accordingly. It might be helpful to show off what I can drive up, but I'll have to drive back down to join the rest of the crew. Lastly our terrain tends to be steep hill climbs and rocky surfaces. Lower gearing lets you attack those trails at a lower speed and with more control. A locker would help in slick and or off-camber situations, but you're still in a situation with the stock gearing where you have to maintain a certain speed to keep from stalling. Like I said different driving, different environment, different needs. Just wanted to share my side of the equation. |
Lockers and Lower gearing are about neck and neck with me too.
Lockers would help to get around the problem of having IFS and make lifting a wheel into less of a problem. Lower T-case gearing would improve going down steep inclines (I have an Automatic), and it would improve my crawl ratio so I could ease my way up obstacles. The whole situation is moot anyway since it wil be awhile before I can afford either. Now back to the original question. You can keep going down in reverse but I think you'll be ok in 4LO, 1st gear. There aren't many trails where 1st and a little braking won't work and I don't think an Xterra has done any of them.
![]() Image from RMXC.org |
Tried it
Thought I would bring this up-to-date.
I tried the downhill in reverse 'trick' with my automatic on a steep paved stretch. It started off VERY slow, the engine bucked 2 or 3 times and then died. I was trying to guide a 4000 lb sled to the bottom without power steering or power brakes - difficult. Good thing is was a short section with a clear run-out at the bottom. Not being too bright, I tried it again. Same results. However I recently read about another technique that I will try when I get back from vacation. Toy Man. |
