Can anyone help me with a ignition timing question. I replaced the head on an 86 toy 4x4 turbo with rebuilt head (Head gasket went bad and cracked head due to water). Put the crank at 0 degrees TDC and marked cam and chain when removing head. After new head was installed made sure it was at 0 degrees TDC and put in distrubtor so it was pointing to #1 wire. Timed truck to 5 degress BTDC and truck ran but had no power. Found that when I advanced the timing say to 12 degress BTDC it was much better. Then moved to say about 20 degrees and truck seemed to run pretty much normal. Does anyone know what might have happened?
If its a 22re you have to short circuit the check connectors in you diagnostics box(right front tire well). I believe its terminals TE1 and E1.Then adjust timing after they have been shorted. When they short it will cause your truck to idle down.
Re: 22R-Te Ignition Timing
Did you replace the timing chain and guides? If not and you have some miles on the engine these guides wear out (especially the right side drivers) and the chain gets loose. This could cause the chain to jump a knotch or worse yet break like mine did!
