1993 Sable, Rear brake lock up?
I have a 1993 Sable. The problem is that the rear left caliper lock up, rotors gets red hot. Once in a while it does it. I replaced the caliper and the fluid seperator next to the caliper. Any comments would help. BTW i heard something with the ABS braking. ANyone know what fuse is the ABS is. Thanks
Re: 1993 Sable, Rear brake lock up?
Need some help. Any help????
did you know
im not sure where the fuse is but your manual should tell you if you still have it. but more importantly did you know that the 93 sable had a recall on its rear abs. if that recall was not done on the car then youre screwed. and that would tell you whats wrong with it. you can get a list of the recalls as i did for my 93 sable by registering with autozone.com it after registering it will give you options one of them if view recall list. and it has quite a few recalls, one of them is youre rear abs. good luck.
