Questions for some of the more knowing...
FIrst off, yes. this is not the right forum, but try to get ANYTHING out of the J30 area and you'll realize why i am putting this here.
i'm wanting to put more inside of my car performance wise. It's a 93 J30t by infiniti. i already have bosch platinum +4 sparkplugs, pro rated fuel filter, a new pcv valve, and besides that, it's stock. what can i do that will increase my car's potential and not wreck my checkbook? also i've noticed that about 80mph my car begins to rattle and shake.. .but then stops at 90... i haven't a clue on what causes that. oh, and also my car is idling really wierd (like 400-800 instead of 1100) but it fluctuates... like it'll be at 800, then drop to 200, the go up to 1100. any ideas? ALL input is appreciated. |
Re: Questions for some of the more knowing...
Is the car pretty much stock??
Plugs probably run too hot for it. Try a more basic plug. Maybe something from the factory.
1999 Pontiac Trans Am WS.6 #1747 Stock'ish' |
nah it was doing thta before i switched plugs (the idling all of it...) and they are recommended for it as well (it's platinum tipped...)
You probably have some kind of Throttle Positioning Sensor that is causing your RPMs to fluctuate like that.
I would assume its in the TB somewhere, but I really have no idea for that type of vehicle.
**1966 Chevy II** ![]() 355 SBC, Turbo 400, 5.13 gear, IHRA Certified to 8.50 in the 1/4 Last Race (10-6-07) So its been awhile... Dial: 6.77, RT: -.0001, 60': 1.4360, 1/8th: 6.7942 @ 100.65 mph Fastest Pass of '07 (10-6-07) 60': 1.4360, 330': 4.3453, 1/8th: 6.7942 @ 100.65 mph 25 and in BIG TIME Debt Crew member #2 Deuce's Wild Racing: Take a Ride on the WILD SIDE
ok, well what about performance? what can i do?
Yeah, it sounds like you need to adjust your TPS sensor. Lemme go check on where it is on the Tib. I'm pretty sure there should be some sort of screw on the TB that you can tighten down to fix that.
As for performance, upgrade the big 3: Intake/Exhaust/Headers. Lightweight pulleys would help too. You could also have the Intake Manifold bored up. If you do that, be sure to get a bigger throttle body. If you have more to spend, you could get a fuel-tuning system, better fuel injectors, high duration cams, high comp pistons, etc.
2001 Hyundai Tiburon - SOLD 2001 Honda S2000 - The New Hotness |
It could also be your oxygen or MAP sensor.
As far as racing performance, new spark plugs, cables won't do pretty much anything that will make you go faster, unless the old ones were really bad. I consider new sparkplugs and a new fuel filter maintnance, not performance mods...at least not most cars on this forum. You should check an infinity forum to see what the best mods would be. All cars respond to different mods differently.
540i/6 w/ SP |
a big ricer wing and lots of stickers will make it SOOO fast!
Rest In Peace, Rich Hall my baby: 1986 Fiero GT: v6, automatic, 2.8L, 2.02/1.60 heads, Crane Performance Cam, Ported/polished exhaust manifolds, taylor plug wires, low temp thermostat and fan switch. WCF catback exhaust She's done!
hmm...the +4's are a waste of money i've heard...but i would at least modify the intake, headers, find a y-pipe, high-flow cat, exhaust.
As it was said by Mister Sinister (it woulda been me, if my internet hadn't crapped out seconds beofre I hit 'submit post', lol), the best bang for your buck is gonna come from Intake, Exhasut, Headers, and possibly a bigger throttle body. The engine is basically a giant air pump, and the best way to get it to work better is to let it breath more freely. Once you get those, see if you can find a chip or software to take advantage of those mods. Then, put your car on a diet.
2006 Redline Red Nissan 350Z Base K&N|Falken I am just that JDM tight, yo.
Just a shot in the dark here, since I know absolutely nothing about your car, but does the t stand for turbo? If so, can the stock block handle more boost?
-Dave '02 Dakota 5.9 R/T Intercooled Paxton - 11.3@120 425/W5/nitrous setup coming soon |
the shaking sounds more like you need your wheels balanced, since its only at a certain speed that does it, this means that the wheel is tramping and shimmying at a certain frequency thats causing it to shake. i think if its a tps sensor then it always bog down whenever it hits that throttle angle.
also if its the 02 sensor, he would notice a big drop in fuel economy. it sounds like either a unbalanced front wheel or wheels, lift up the front of the car, to check if your front end is loose ( check tie rods ends,ball joints, and wheel bearing ) you can check by lifting the up, and by tryin to wiggle the wheel. if it wiggles, theres your problem.
303whp stock internal KA-T 94 Acura NSX Best E.T. 13.559 Best Trap speed 107.62 mph |
the T stands for touring.
iirc, that's detuned 300zx motor in that car. there are plenty of mods available for that thing. for the poor idle, i'd say it's either the idle air control valve(iacv) or your PCV valve. Also check your Mass Airflow Sensor.
BP's Rides; - 2005 Kawasaki Ninja ZX6R- Mods: ECU Jumper, Akrapovic Slip-on, Power Commander III, 8000K HID's. - 2K2 Maxima 6 Speed-Mods: Advanced Timing, Cattman Cat-back Exhaust, H&R Springs, Tokico Illumina Struts, Konig Theory 19" Rims. ![]() ![]() ![]()
Re: Re: Questions for some of the more knowing...
Also when to do the software depends a lot on what is available. With the exception of the bigger throttle body, most plug-and-play software won't have different programming for intake, exhaust, pullies, or headers. If you're going the custom tuning route, then you'll definitely want to do the software last.
2004 Subaru Impreza WRX STI (daily driver) ![]() 1999 Mazda Miata (track car, slow, but finished the SCCA Runoffs) 1987 Porsche 944 (being rebuilt)
Not neccessarely. When I got the header in my old civic, the O2 sensor started acting up and I had an erratic idle, but I got better MPG. I was averaging over 40 mpg on the highway whereas it was less before that. Once I replaced it, it went back to below 40 mpg. The reason I know this is because I used to take the same long trips week after week and I'd have more gas left after the 02 sensor started acting up. A lot of people think the car always runs rich after the 02 sensor goes, but that's not always true. But you're right that the MPG should change since the ECU doesn't know how much fuel it needs. But it can also be a benefit MPG wise, but obviously you'll lose performance since not enough fuel is injected to go fast.
540i/6 w/ SP |
